주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Meizu MX3 Volume Control and Power Button Replacement
필요한 것
  1. Meizu MX3 Volume Control and Power Button Replacement, Removing the Back Cover: 1 단계, 이미지 3개 중 1개 Meizu MX3 Volume Control and Power Button Replacement, Removing the Back Cover: 1 단계, 이미지 3개 중 2개 Meizu MX3 Volume Control and Power Button Replacement, Removing the Back Cover: 1 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool in between the charging port and the back case of the device. Slowly move the tool to the left of the until you come the top by the power button.
    • Using a paper clip or pointed edge spudger push in the pin located in the bottom right hand corner of the back of the phone.
    댓글 쓰기
  2. Meizu MX3 Volume Control and Power Button Replacement, Removing the Screws in the Internal Casing: 2 단계, 이미지 3개 중 1개 Meizu MX3 Volume Control and Power Button Replacement, Removing the Screws in the Internal Casing: 2 단계, 이미지 3개 중 2개 Meizu MX3 Volume Control and Power Button Replacement, Removing the Screws in the Internal Casing: 2 단계, 이미지 3개 중 3개
    • Using one of the small Phillips screwdriver bits provided unscrew the 11 screws present on the protective plastic plate under the device case.
    댓글 쓰기
  3. Meizu MX3 Volume Control and Power Button Replacement, Removing the Internal Casing: 3 단계, 이미지 3개 중 1개 Meizu MX3 Volume Control and Power Button Replacement, Removing the Internal Casing: 3 단계, 이미지 3개 중 2개 Meizu MX3 Volume Control and Power Button Replacement, Removing the Internal Casing: 3 단계, 이미지 3개 중 3개
    • After the 11 screws are loosened use the plastic opening tool and gently pry the protective plate from the back of the device.
    • Once the plate is off, use the same tool to gently remove the 3 ribbon cables located directly above the battery.
    • On the left side of the battery on the phone case, there is a groove where the plastic opening tool can be inserted to pry the battery up and out. The battery might be glued to the phone so exercise caution.
    • Note: The battery and motherboard does not need to be removed in order replace power and volume buttons.
    댓글 쓰기
  4. Meizu MX3 Volume Control and Power Button Replacement, Removing the Power and Volume Buttons: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • After the plastic plate is removed, tweezers can be used to remove and replace the power and volume buttons from the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Mandela Robin
회원 가입일: 09/23/14
876 평판
안내서 6개를 작성함
USF Tampa, Team 15-2, Remmell Fall 2014 USF Tampa, Team 15-2, Remmell Fall 2014 회원
USFT-REMMELL-F14S15G2
4 회원들
안내서 27개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 36
전체 시간: 2,235
