주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Merch Source Projector Entertainment II Outer Lens Replacement
필요한 것
    1. Merch Source Projector Entertainment II Outer Lens Replacement, Outer Casing: 1 단계, 이미지 2개 중 1개 Merch Source Projector Entertainment II Outer Lens Replacement, Outer Casing: 1 단계, 이미지 2개 중 2개
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
      댓글 쓰기
    2. Merch Source Projector Entertainment II Outer Lens Replacement: 2 단계, 이미지 1개 중 1개
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
      댓글 쓰기
    3. Merch Source Projector Entertainment II Outer Lens Replacement: 3 단계, 이미지 2개 중 1개 Merch Source Projector Entertainment II Outer Lens Replacement: 3 단계, 이미지 2개 중 2개
      • Using your hands, gently pry the top and bottom of the projector casing apart.
      댓글 쓰기
    1. Merch Source Projector Entertainment II Outer Lens Replacement, Ribbon Cable Detachment: 4 단계, 이미지 2개 중 1개 Merch Source Projector Entertainment II Outer Lens Replacement, Ribbon Cable Detachment: 4 단계, 이미지 2개 중 2개
      • Use the plastic opening tool to gently disengage the black clip housing from the ribbon cable.
      • Once the ribbon cable is disengaged gently pull the cable off the motherboard.
      • Once the housing is disengaged, the ribbon cable should slide out easily. Do not pull too hard on the ribbon cable as it is very fragile.
      댓글 쓰기
    2. Merch Source Projector Entertainment II Outer Lens Replacement, Motherboard Detachment: 5 단계, 이미지 3개 중 1개 Merch Source Projector Entertainment II Outer Lens Replacement, Motherboard Detachment: 5 단계, 이미지 3개 중 2개 Merch Source Projector Entertainment II Outer Lens Replacement, Motherboard Detachment: 5 단계, 이미지 3개 중 3개
      • Unscrew the three 7 mm screws from the motherboard with the Phillips #0 screw driver.
      • Once loose, lift the motherboard off of the lens casing, and move it away from the workspace.
      • Be sure not to damage any of the wires atached to the motherboard.
      댓글 쓰기
    3. Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Detachment: 6 단계, 이미지 3개 중 1개 Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Detachment: 6 단계, 이미지 3개 중 2개 Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Detachment: 6 단계, 이미지 3개 중 3개
      • Unscrew the four 15mm Phillips screws using the Phillips #0 screw driver.
      • Unscrew the two 12mm Phillips screws using the Phillips #0 screw driver.
      • Gently remove the entire lens casing from its position.
      댓글 쓰기
    4. Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Seperation: 7 단계, 이미지 3개 중 1개 Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Seperation: 7 단계, 이미지 3개 중 2개 Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Seperation: 7 단계, 이미지 3개 중 3개
      • Using the plastic opening tool, slightly separate the casing holding the large lens in place.
      • Separate the casing completely from the inner lens using your hands.
      • This should release the outer lens and it's immediate casing.
      • As you separate the outer casing, the lens and digital display box may fall out of their encasement.
      • Although there are threads connecting the outer lens casing and the inner lens casing, do not be fooled. The outer lens casing cannot be disconnected by unscrewing it.
      댓글 쓰기
    5. Merch Source Projector Entertainment II Outer Lens Replacement, Outer Lens Casing Seperation: 8 단계, 이미지 3개 중 1개 Merch Source Projector Entertainment II Outer Lens Replacement, Outer Lens Casing Seperation: 8 단계, 이미지 3개 중 2개 Merch Source Projector Entertainment II Outer Lens Replacement, Outer Lens Casing Seperation: 8 단계, 이미지 3개 중 3개
      • Unscrew the four 8mm Phillips screws at the base of the outer lens casing using the Phillips #0 screw driver.
      • Separate the white outer casing from the black outer casing.
      댓글 쓰기
    6. Merch Source Projector Entertainment II Outer Lens Replacement, Final Outer Lens Removal: 9 단계, 이미지 2개 중 1개 Merch Source Projector Entertainment II Outer Lens Replacement, Final Outer Lens Removal: 9 단계, 이미지 2개 중 2개
      • Using your finger, gently push the lens out of its white encasement.
      • The outer lens is now free and ready for replacement.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Stephanie
회원 가입일: 01/08/15
282 평판
안내서 3개를 작성함
Cal Poly, Team 18-3, Maness Winter 2015 Cal Poly, Team 18-3, Maness Winter 2015 회원
CPSU-MANESS-W15S18G3
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 38
전체 시간: 3,626
