주요 콘텐츠로 건너뛰기
Meta Quest 2 Controller Thumbgrip Replacement
필요한 것
  1. Meta Quest 2 Controller Thumbgrip Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Thumbgrip Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Thumbgrip Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 3개
    • Use your fingers to slide the battery cover down towards the strap end of the controller.
    • Remove the battery cover.
    • If you're taking the controller apart for repairs, remove the batteries in the controller.
  2. Meta Quest 2 Controller Thumbgrip Replacement, Loosen the faceplate adhesive: 2 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the bottom edge of the controller faceplate for a minute.
  3. Meta Quest 2 Controller Thumbgrip Replacement, Loosen the controller faceplate: 3 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Thumbgrip Replacement, Loosen the controller faceplate: 3 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Thumbgrip Replacement, Loosen the controller faceplate: 3 단계, 이미지 3개 중 3개
    • The controller faceplate is secured with adhesive and three friction pegs.
    • Press the edge of an opening tool into the seam between the controller faceplate and shell, near the Oculus button.
    • If you can’t get the opening tool into the seam, heat the area with an iOpener for a minute and try again.
    • Slide the opening tool to the base of the ring shell to loosen the adhesive.
  4. Meta Quest 2 Controller Thumbgrip Replacement: 4 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Thumbgrip Replacement: 4 단계, 이미지 2개 중 2개
    • Use an opening tool to pry up on the seam to loosen the first friction peg.
  5. Meta Quest 2 Controller Thumbgrip Replacement: 5 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Thumbgrip Replacement: 5 단계, 이미지 2개 중 2개
    • Continue prying around the entire faceplate to separate the remaining friction pegs and adhesive.
    • If you're having trouble, apply a heated iOpener to the faceplate for a minute and try again.
  6. Meta Quest 2 Controller Thumbgrip Replacement, Remove the faceplate: 6 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Thumbgrip Replacement, Remove the faceplate: 6 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Thumbgrip Replacement, Remove the faceplate: 6 단계, 이미지 3개 중 3개
    • Remove the controller faceplate.
    • The three friction pegs should hold the faceplate securely, so you don’t need to replace the adhesive during reassembly. Be sure to firmly press the faceplate onto the controller so that all friction pegs fully engage.
  7. Meta Quest 2 Controller Thumbgrip Replacement, Remove the thumbgrip: 7 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Thumbgrip Replacement, Remove the thumbgrip: 7 단계, 이미지 2개 중 2개
    • Use your fingers to pull the thumbgrip straight off of the thumbstick and remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
313,851 평판
안내서 729개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 87
전체 시간: 1,861
