주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Meta Quest 2 Controller Joystick Replacement
필요한 것
    1. Meta Quest 2 Controller Joystick Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Joystick Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Joystick Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 3개
      • Use your fingers to slide the battery cover down towards the strap end of the controller.
      • Remove the battery cover.
      • If you're taking the controller apart for repairs, remove the batteries in the controller.
      댓글 쓰기
    1. Meta Quest 2 Controller Joystick Replacement, Remove the wrist strap: 2 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Joystick Replacement, Remove the wrist strap: 2 단계, 이미지 2개 중 2개
      • Use your fingers to grasp the wrist strap near the anchor peg.
      • Lift the wrist strap anchor peg straight out of its recess.
      • Remove the wrist strap.
      댓글 쓰기
    1. Meta Quest 2 Controller Joystick Replacement, Loosen the faceplate adhesive: 3 단계, 이미지 1개 중 1개
      • Heat an iOpener and apply it to the bottom edge of the controller faceplate for a minute.
      댓글 쓰기
    2. Meta Quest 2 Controller Joystick Replacement, Loosen the controller faceplate: 4 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Joystick Replacement, Loosen the controller faceplate: 4 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Joystick Replacement, Loosen the controller faceplate: 4 단계, 이미지 3개 중 3개
      • The controller faceplate is secured with adhesive and three friction pegs.
      • Press the edge of an opening tool into the seam between the controller faceplate and shell, near the Oculus button.
      • If you can’t get the opening tool into the seam, heat the area with an iOpener for a minute and try again.
      • Slide the opening tool to the base of the ring shell to loosen the adhesive.
      댓글 쓰기
    3. Meta Quest 2 Controller Joystick Replacement: 5 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Joystick Replacement: 5 단계, 이미지 2개 중 2개
      • Use an opening tool to pry up on the seam to loosen the first friction peg.
      댓글 쓰기
    4. Meta Quest 2 Controller Joystick Replacement: 6 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Joystick Replacement: 6 단계, 이미지 2개 중 2개
      • Continue prying around the entire faceplate to separate the remaining friction pegs and adhesive.
      • If you're having trouble, apply a heated iOpener to the faceplate for a minute and try again.
      댓글 쓰기
    5. Meta Quest 2 Controller Joystick Replacement, Remove the faceplate: 7 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Joystick Replacement, Remove the faceplate: 7 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Joystick Replacement, Remove the faceplate: 7 단계, 이미지 3개 중 3개
      • Remove the controller faceplate.
      • The three friction pegs should hold the faceplate securely, so you don’t need to replace the adhesive during reassembly. Be sure to firmly press the faceplate onto the controller so that all friction pegs fully engage.
      댓글 쓰기
    1. Meta Quest 2 Controller Joystick Replacement, Loosen the controller ring shell: 8 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Joystick Replacement, Loosen the controller ring shell: 8 단계, 이미지 2개 중 2개
      • Use a Torx T5 driver to remove the four screws securing the controller ring shell to the controller:
      • Two 4.7 mm‑long screws
      • Two 5.9 mm‑long screws
      댓글 쓰기
    2. Meta Quest 2 Controller Joystick Replacement: 9 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Joystick Replacement: 9 단계, 이미지 2개 중 2개
      • Press the point of a spudger firmly against the white alignment square to release the ring shell.
      댓글 쓰기
    3. Meta Quest 2 Controller Joystick Replacement, Remove the controller ring shell: 10 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Joystick Replacement, Remove the controller ring shell: 10 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Joystick Replacement, Remove the controller ring shell: 10 단계, 이미지 3개 중 3개
      • Use your fingers to grab the end of the ring shell that doesn’t have the white alignment square.
      • Gently lift the ring shell up and away from the controller to unclip it from the controller.
      • Remove the controller ring shell.
      댓글 쓰기
    1. Meta Quest 2 Controller Joystick Replacement, Loosen the side shell: 11 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Joystick Replacement, Loosen the side shell: 11 단계, 이미지 2개 중 2개
      • Use a Torx T5 driver to remove the five screws:
      • One 11.5 mm‑long screw
      • Three 5.9 mm‑long screws
      • One 18.2 mm‑long screw
      댓글 쓰기
    2. Meta Quest 2 Controller Joystick Replacement, Remove the battery label: 12 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use tweezers and your fingers to peel the battery information label out from the battery compartment.
      • If you want to reuse this sticker, be careful not to tear it. If it’s difficult to peel, apply a heated iOpener to it for a minute to soften the label adhesive.
      댓글 쓰기
    3. Meta Quest 2 Controller Joystick Replacement, Loosen the side shell: 13 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Joystick Replacement, Loosen the side shell: 13 단계, 이미지 2개 중 2개
      • Use a Torx T5 driver to remove the four 5.9 mm‑long screws securing the side shell to the controller:
      • Three screws inside the battery compartment
      • One screw near the corner of the battery compartment
      댓글 쓰기
    4. Meta Quest 2 Controller Joystick Replacement: 14 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Joystick Replacement: 14 단계, 이미지 2개 중 2개
      • Pull the bottom of the side shell slightly away from the controller to loosen the shell.
      • You may hear a few clicks as the clips release. This is normal.
      댓글 쓰기
    5. Meta Quest 2 Controller Joystick Replacement: 15 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Joystick Replacement: 15 단계, 이미지 2개 중 2개
      • Part of the side shell is looped around a screw post. In this step, you’ll spread the screw post apart enough to slip the shell out.
      • Insert the flat end of a spudger into the gap between the controller ring and the front shell.
      • The front shell is the plastic frame part below the front trigger.
      • Twist the spudger to widen the gap between the front shell and the controller.
      • Position the spudger so that it can stay in place without you holding the tool.
      댓글 쓰기
    6. Meta Quest 2 Controller Joystick Replacement, Remove the side shell: 16 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Joystick Replacement, Remove the side shell: 16 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Joystick Replacement, Remove the side shell: 16 단계, 이미지 3개 중 3개
      • Guide the looped part of the side shell through the screw post gap.
      • Remove the side shell.
      댓글 쓰기
    7. Meta Quest 2 Controller Joystick Replacement, Reassembly note: 17 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Joystick Replacement, Reassembly note: 17 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Joystick Replacement, Reassembly note: 17 단계, 이미지 3개 중 3개
      • During reassembly:
      • Spread the screw post wide enough to loop the side shell back around it.
      • Be careful not to pinch the antenna cable or the tracking flex cable as you reposition the side shell.
      댓글 쓰기
    1. Meta Quest 2 Controller Joystick Replacement, Remove the Controller Front Shell: 18 단계, 이미지 1개 중 1개
      • Use a spudger or an opening pick to gently pry the shell from the battery compartment side first.
      • Once it pops open, turn the controller over to remove the front shell.
      • If you have trouble, move to the next step.
      댓글 쓰기
    2. Meta Quest 2 Controller Joystick Replacement: 19 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Joystick Replacement: 19 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Joystick Replacement: 19 단계, 이미지 3개 중 3개
      • If you successfully removed the front shell, skip this step.
      • Grasp the front shell near the bottom of the controller.
      • Lift and pull the bottom edge of the front shell outwards slightly to clear the plastic alignment peg.
      • The alignment peg breaks easily. Make sure you lift the shell enough to clear it.
      댓글 쓰기
    3. Meta Quest 2 Controller Joystick Replacement: 20 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Joystick Replacement: 20 단계, 이미지 2개 중 2개
      • Pull the front shell away from the controller and remove it.
      댓글 쓰기
    4. Meta Quest 2 Controller Joystick Replacement, Remove the front trigger pin: 21 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Joystick Replacement, Remove the front trigger pin: 21 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Joystick Replacement, Remove the front trigger pin: 21 단계, 이미지 3개 중 3개
      • Use a driver bit (such as the Torx T5) or the point of a spudger to push the front trigger pin out from the side shown. Pushing from the opposite side can cause the pin to rip the sensor cable.
      • For better reach, you can also use a straightened paper clip or the point of your tweezers.
      댓글 쓰기
    5. Meta Quest 2 Controller Joystick Replacement: 22 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Hold the front trigger with your finger to prevent the trigger from flying out.
      • Use tweezers or your fingers to pull the trigger pin out.
      댓글 쓰기
    6. Meta Quest 2 Controller Joystick Replacement, Remove the front trigger: 23 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Joystick Replacement, Remove the front trigger: 23 단계, 이미지 2개 중 2개
      댓글 쓰기
    1. Meta Quest 2 Controller Joystick Replacement, Disconnect the controller board: 24 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Joystick Replacement, Disconnect the controller board: 24 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use a clean fingernail or tweezers to flip up the ZIF socket's lock bar securing the outer tracking flex cable.
      댓글 쓰기
    2. Meta Quest 2 Controller Joystick Replacement: 25 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Joystick Replacement: 25 단계, 이미지 2개 중 2개
      • Use tweezers to grasp the outer tracking flex cable by its pull tab and pull it out of its ZIF socket.
      댓글 쓰기
    3. Meta Quest 2 Controller Joystick Replacement: 26 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Joystick Replacement: 26 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Joystick Replacement: 26 단계, 이미지 3개 중 3개
      • Use the same procedure to unlock and disconnect the inner tracking flex cable from its ZIF socket.
      댓글 쓰기
    4. Meta Quest 2 Controller Joystick Replacement: 27 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Joystick Replacement: 27 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Joystick Replacement: 27 단계, 이미지 3개 중 3개
      • Use a clean fingernail or tweezers to unlock and disconnect the joystick flex cable from its ZIF socket.
      댓글 쓰기
    5. Meta Quest 2 Controller Joystick Replacement: 28 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Joystick Replacement: 28 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Joystick Replacement: 28 단계, 이미지 3개 중 3개
      • Insert one arm of a pair of tweezers under the metal neck of the antenna cable.
      • Pry straight up to disconnect the antenna from the controller board.
      • Gently pull the antenna to unclip it from its grounding clip.
      댓글 쓰기
    6. Meta Quest 2 Controller Joystick Replacement: 29 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Joystick Replacement: 29 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Joystick Replacement: 29 단계, 이미지 3개 중 3개
      • Use a clean fingernail or tweezers to unlock and disconnect the interconnect flex cable from its ZIF socket.
      댓글 쓰기
    7. Meta Quest 2 Controller Joystick Replacement, Loosen the battery shell: 30 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Joystick Replacement, Loosen the battery shell: 30 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Joystick Replacement, Loosen the battery shell: 30 단계, 이미지 3개 중 3개
      • The battery shell is the plastic frame part that holds the batteries.
      • Use your fingers to twist the battery shell slightly so that its edge near the thumbstick clicks out of place.
      댓글 쓰기
    8. Meta Quest 2 Controller Joystick Replacement: 31 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Joystick Replacement: 31 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Joystick Replacement: 31 단계, 이미지 3개 중 3개
      • There’s a friction assembly near the vibration motor that needs to separate in order to remove the battery shell.
      • Gently wiggle the battery shell as you pull it away from the controller.
      • Remove the battery shell.
      댓글 쓰기
    9. Meta Quest 2 Controller Joystick Replacement, Unfasten the controller board: 32 단계, 이미지 1개 중 1개
      • Use a Torx T5 driver to remove the four 7.5 mm‑long screws securing the controller board.
      • During reassembly, be careful not to overtighten these screws, or you may break them.
      댓글 쓰기
    10. Meta Quest 2 Controller Joystick Replacement, Remove the controller board: 33 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Joystick Replacement, Remove the controller board: 33 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Joystick Replacement, Remove the controller board: 33 단계, 이미지 3개 중 3개
      • Use your fingers to lift the controller board out of the shell and remove it.
      댓글 쓰기
    1. Meta Quest 2 Controller Joystick Replacement, Remove the joystick: 34 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Joystick Replacement, Remove the joystick: 34 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use your fingers or tweezers to remove the joystick.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 44명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
344,482 평판
안내서 915개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 40,578개를 작성함
11가이드 댓글
When replacing the joystick, make sure you place the metal cover on the right side, the joystick goes under the circuit board, and make sure the little metal flap is bent enough, also make sure the screws are tight.
id recommend this video so you get more what i mean, although it doesn't show exactly that i mean.
https://youtu.be/kQ2-XYEbOKY?t=98
otherwise you wont have the touch pad on the joystick, it'll still work good, just no sensing if you have your finger on it
Endakid - 답글 공유
You dont need to remove the pin/take of the tigger, if youre carful and paitent
id say its safer to leave it in
Endakid - 답글 공유
Can confirm. I looked at this guide before looking at any videos (all of which do not take the trigger out) and I must have bent the pin/spring when putting it back in because my trigger won't go back up now. I also broke the front shell alignment peg when going back to try to try again. Please update this guide so this doesn't happen to anyone else.
MikeyLORR - 답글 공유
thank you for the guide, i am yet to do it, why is the anolog the first last thing to come out when they are notorious to breaking
Harry Chamberlain - 답글 공유
I know right, seriously this is one of the worst repair jobs I've done lately.
T-S - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 82
지난 7일: 485
지난 30일: 2,377
전체 시간: 61,248
