주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microsoft Band Battery Replacement
필요한 것
    1. Microsoft Band Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Unscrew both side panel 2mm screws using the T3 Torx screwdriver.
      댓글 쓰기
    2. Microsoft Band Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Firmly pry up the side panel using the plastic spudger to break the waterproof seal and lift the battery panel.
      댓글 쓰기
    3. Microsoft Band Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Gently pry up one edge of the battery with the plastic spudger.
      댓글 쓰기
    4. Microsoft Band Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Remove battery from its compartment with your fingers.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Replace the vibrator in its original compartment.
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Monique Salinger
회원 가입일: 02/01/15
408 평판
안내서 2개를 작성함
Cal Poly, Team 17-34, Amido Winter 2015 Cal Poly, Team 17-34, Amido Winter 2015 회원
CPSU-AMIDO-W15S17G34
4 회원들
안내서 12개를 작성함
5가이드 댓글
where can i buy the battery?
chirac - 답글 공유
From what I can tell it's something like this:
http://www.alibaba.com/product-detail/Ho...
which is a 3.7v flat lithium ion polymer 72mAh battery. Min order is 1030 though! You can find similar on AliExpress if you search for that description. The dimensions are listed as 4*14.8*21.5mm so it'll need to be within that, or maybe the OP can confirm the battery size?
Simon - 답글 공유
Will this be dangerous?
Rei zzstu Shiozawa - 답글 공유
Anyway to upgrade to a higher capacity battery to get better life out of it? With GPS on, it dies in 2 hours and I go on 8 hr hikes.
Chris Green - 답글 공유
No tak wszystko fajnie ale gdzie te akumulatory zakupić ?
Tomasz Sot - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 51
전체 시간: 12,603
