주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microsoft Kinect Tilt Motor Replacement
필요한 것
  1. Microsoft Kinect Tilt Motor Replacement, Tilt Motor: 1 단계, 이미지 1개 중 1개
    • Pull the rubber backing off the base of the Kinect.
    • If the adhesive attaching the rubber backing and the base doesn't come off with the rubber backing, remove the adhesive as well.
    • If the adhesive comes off separately, you may some type of adhesive to reattach the rubber backing.
    댓글 쓰기
  2. Microsoft Kinect Tilt Motor Replacement: 2 단계, 이미지 2개 중 1개 Microsoft Kinect Tilt Motor Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the four 7mm T6 Torx screws.
    • Pull off the base to reveal the inner case.
    댓글 쓰기
  3. Microsoft Kinect Tilt Motor Replacement: 3 단계, 이미지 3개 중 1개 Microsoft Kinect Tilt Motor Replacement: 3 단계, 이미지 3개 중 2개 Microsoft Kinect Tilt Motor Replacement: 3 단계, 이미지 3개 중 3개
    • Unscrew the four 5mm #0 Phillip screws.
    • These screws strip easily.
    • Remove the metal plate to reveal the motor and gears.
    • Disconnect the connector to separate the plate from the Kinect.
    댓글 쓰기
  4. Microsoft Kinect Tilt Motor Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the three gears on top of the motor, starting with the center gear.
    댓글 쓰기
  5. Microsoft Kinect Tilt Motor Replacement: 5 단계, 이미지 2개 중 1개 Microsoft Kinect Tilt Motor Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew the four 5mm #00 Phillip screws.
    • Remove the motor from the plate to replace.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Daniel
회원 가입일: 04/20/15
395 평판
안내서 1개를 작성함
Cal Poly, Team 14-7, Amido Spring 2015 Cal Poly, Team 14-7, Amido Spring 2015 회원
CPSU-AMIDO-S15S14G7
4 회원들
안내서 12개를 작성함
2가이드 댓글
Be careful not to lose the spring & washer ! ( It’s also missing a step showing where the brass washer goes )https://www.zdnet.com/pictures/microsoft...
Bantum Works - 답글 공유
So far the isn’t a mention replacement of the plastic “post” that the tilt motor and the upper sensor unit are joined at. Mine broke (that’s what happens when you get a “free Xbox 360” at a neighborhood moving sale.) I couldn’t get the base plate apart as my T5 torx bit is trashed. So, my solution?…epoxy the heck out of the post as it’s only purpose is to hold the two units of the Kinect together. So far it worked!
David C - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 23
지난 30일: 98
전체 시간: 5,962
