주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microsoft Surface 2 Volume Control Replacement
필요한 것
    1. Microsoft Surface 2 Volume Control Replacement, Screen: 1 단계, 이미지 3개 중 1개 Microsoft Surface 2 Volume Control Replacement, Screen: 1 단계, 이미지 3개 중 2개 Microsoft Surface 2 Volume Control Replacement, Screen: 1 단계, 이미지 3개 중 3개
      • Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
      • Avoid holding the heat gun too close to the Microsoft Surface 2 so as to not cause any unwanted warping.
      • Avoid touching the metal end of the gun. It will be very hot and can burn you.
      • Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
      • Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
      댓글 쓰기
    2. Microsoft Surface 2 Volume Control Replacement: 2 단계, 이미지 3개 중 1개 Microsoft Surface 2 Volume Control Replacement: 2 단계, 이미지 3개 중 2개 Microsoft Surface 2 Volume Control Replacement: 2 단계, 이미지 3개 중 3개
      • Once the screen is free from the body, there will be a single ribbon cable connecting the screen to the motherboard.
      • Use a plastic spudger to pry the retaining clip away from the display cable.
      • The ribbon cable may be glued to the motherboard.
      • Carefully pull the ribbon cable from its socket on the motherboard.
      댓글 쓰기
    1. Microsoft Surface 2 Volume Control Replacement, Volume Control: 3 단계, 이미지 2개 중 1개 Microsoft Surface 2 Volume Control Replacement, Volume Control: 3 단계, 이미지 2개 중 2개
      • Work close to Magnetic Project Map to avoid losing screws.
      • Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
      • Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
      • Once all screws have been removed, lift and remove the bezel from the rest of the device.
      댓글 쓰기
    2. Microsoft Surface 2 Volume Control Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Gently peel off the yellow plastic tape using a pair of tweezers.
      댓글 쓰기
    3. Microsoft Surface 2 Volume Control Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the two 1.70 mm T3 screws from the volume control switch.
      댓글 쓰기
    4. Microsoft Surface 2 Volume Control Replacement: 6 단계, 이미지 1개 중 1개
      • Use a spudger to lift up the retaining flap on the volume control cable ZIF connector.
      • Make sure you are prying up on the retaining flap, not the connector itself.
      댓글 쓰기
    5. Microsoft Surface 2 Volume Control Replacement: 7 단계, 이미지 1개 중 1개
      • Now that the volume control switch is loose, pull it gently away from the motherboard.
      • No force is needed to plug in or remove the ribbon cable.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
oluchianya
회원 가입일: 02/04/16
157 평판
안내서 1개를 작성함
USF Tampa, Team 3-1, Wollert Spring 2016 USF Tampa, Team 3-1, Wollert Spring 2016 회원
USFT-WOLLERT-S16S3G1
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 62
전체 시간: 2,046
