주요 콘텐츠로 건너뛰기
Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement
필요한 것
  1. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 1/2 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2/2
    • Allow your laptop's battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Flip the laptop over: 2 단계, 이미지 1/2 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Flip the laptop over: 2 단계, 이미지 2/2
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
  3. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Feet removal information: 3 단계, 이미지 1/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Feet removal information: 3 단계, 이미지 2/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Feet removal information: 3 단계, 이미지 3/3
    • Each foot has a recess to help pry it from the laptop:
    • The back feet recesses are closest to the back edge of the laptop.
    • The front feet recesses are closest to the front edge of the laptop.
  4. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Remove the feet: 4 단계, 이미지 1/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Remove the feet: 4 단계, 이미지 2/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Remove the feet: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Insert one arm of your tweezers into the recess of one of the feet.
    • Twist your tweezers and pry up to separate the adhesive and unclip the foot from the laptop.
    • The feet eject very quickly—be careful not to lose them.
    • Remove the foot.
    • Repeat this process on the remaining feet.
  5. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Reassembly information: 5 단계, 이미지 1/2 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Reassembly information: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    구매
    • This laptop has two different types of feet. During reassembly, make sure the feet go in their correct recesses.
    • The rear feet have a single center clip.
    • The front feet have three clips and can only be reinserted one way.
    • Press the feet into their recesses to secure them to the frame.
    • If the existing feet no longer adhere to the frame, remove the old adhesive and apply a small amount of Tesa Tape where the old adhesive was.
  6. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement: 6 단계, 이미지 1/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement: 6 단계, 이미지 2/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement: 6 단계, 이미지 3/3
    • If the feet are damaged or worn out, use 8 mm rubber furniture pads:
    • Peel a pad away from its backing.
    • Align the pad over a foot cavity and press down to secure it.
  7. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Unfasten the upper case: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    FixMat
    $36.95
    구매
    • These screws strip easily. Apply constant, downward force to prevent stripping.
    • Use a T5 Torx driver to remove the four 3 mm screws securing the upper case.
  8. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Open the screen: 8 단계, 이미지 1/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Open the screen: 8 단계, 이미지 2/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Open the screen: 8 단계, 이미지 3/3
    • Flip your laptop over and fully open the screen.
  9. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Lift the upper case: 9 단계, 이미지 1/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Lift the upper case: 9 단계, 이미지 2/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Lift the upper case: 9 단계, 이미지 3/3
    • The upper case is secured by magnets.
    • Grip the top edge of the upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case, as it's still connected to the laptop by a cable.
    • Lift the bottom edge of the upper case up and away from the laptop, taking care to not strain the ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the screen could damage the screen as it closes.
  10. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Disconnect the keyboard and touchpad cable: 10 단계, 이미지 1/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Disconnect the keyboard and touchpad cable: 10 단계, 이미지 2/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Disconnect the keyboard and touchpad cable: 10 단계, 이미지 3/3
    • The keyboard and touchpad cable connects the upper case to the laptop.
    • Insert the pointed end of a spudger under one edge of the magnet connector and pry up to disconnect it.
    • To reconnect the cable, align the magnet connector over its socket with the cable facing the bottom of the laptop. Press down on the connector to secure it.
  11. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Remove the upper case: 11 단계, 이미지 1/1
    • Remove the upper case and set it keyboard-side down on a clean surface.
  12. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Reassembly information: 12 단계, 이미지 1/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Reassembly information: 12 단계, 이미지 2/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Reassembly information: 12 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    구매
    • Your SSD has thermal paste that forms a bond to the upper case.
    • During reassembly:
    • Use the flat end of your spudger to scrape away old thermal paste from the top of the SSD and the underside of the upper case.
    • Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the SSD and upper case. Wipe away the residue using a lint-free or microfiber cloth.
    • Replace the thermal pad with one that's the same size as the SSD sticker.
    • Alternatively, you can apply a bead of thermal paste directly to the SSD's label. Use the dot method with a bead slightly larger than the screw head securing the SSD.
  13. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Unfasten the SSD: 13 단계, 이미지 1/1
    • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
    • With the screw removed, the SSD pops up at a shallow angle.
  14. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Remove the SSD: 14 단계, 이미지 1/2 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Remove the SSD: 14 단계, 이미지 2/2
    • Removing the SSD also functions as a battery disconnect.
    • Pull the SSD out of its socket and remove it.
    • Don't pull up at a sharp angle, as this could damage the SSD and its socket.
    • During reassembly, insert the SSD at a slight angle.
  15. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Disconnect the port connector: 15 단계, 이미지 1/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Disconnect the port connector: 15 단계, 이미지 2/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Disconnect the port connector: 15 단계, 이미지 3/3
    • Use the flat end of spudger to flip open the gold locking arm on the Surface Connect port motherboard connector.
    • Hold the tape out of the way, if necessary.
    • Grip the Surface Connect port cable and pull it away from its connector to disconnect it.
  16. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Unfasten the port cover: 16 단계, 이미지 1/1
    • Use a T3 Torx driver to remove the four screws securing the Surface Connect port cover:
    • Two 2.0 mm screws
    • Two 2.2 mm screws
  17. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Remove the port cover: 17 단계, 이미지 1/2 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Remove the port cover: 17 단계, 이미지 2/2
    • Remove the Surface Connect port cover.
  18. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Unfasten the port: 18 단계, 이미지 1/1
    • Use a T3 Torx driver to remove the two 3 mm screws securing the Surface Connect port.
  19. Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Remove the port: 19 단계, 이미지 1/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Remove the port: 19 단계, 이미지 2/3 Microsoft Surface Laptop 5 (15-inch) Surface Connect Port Replacement, Remove the port: 19 단계, 이미지 3/3
    • Pull the Surface Connect port away from the edge of the chassis and remove it.
결론
Spencer Day
회원 가입일: 09/14/22
55,203 평판
안내서 408개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,430개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 12
전체 시간: 131
