주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microsoft Surface Pro 2 Audio Ports Replacement
필요한 것
  1. Microsoft Surface Pro 2 Audio Ports Replacement, LCD Display: 1 단계, 이미지 2개 중 1개 Microsoft Surface Pro 2 Audio Ports Replacement, LCD Display: 1 단계, 이미지 2개 중 2개
    • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
    댓글 쓰기
  2. Microsoft Surface Pro 2 Audio Ports Replacement: 2 단계, 이미지 1개 중 1개
    • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
    • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
    • The glue is under the darker border of the device display.
    댓글 쓰기
  3. Microsoft Surface Pro 2 Audio Ports Replacement: 3 단계, 이미지 1개 중 1개
    • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
    • If the tool does not easily slide under the screen, return to heating before proceeding.
    • Slowly work the tool around the entire edge of the screen.
    댓글 쓰기
  4. Microsoft Surface Pro 2 Audio Ports Replacement: 4 단계, 이미지 3개 중 1개 Microsoft Surface Pro 2 Audio Ports Replacement: 4 단계, 이미지 3개 중 2개 Microsoft Surface Pro 2 Audio Ports Replacement: 4 단계, 이미지 3개 중 3개
    • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
    • Please note the third small connector in red.
    • Allow the glue to cool before letting it come into contact with any other surface.
    댓글 쓰기
  5. Microsoft Surface Pro 2 Audio Ports Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 Microsoft Surface Pro 2 Audio Ports Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 Microsoft Surface Pro 2 Audio Ports Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
    • Make sure that the front-facing camera is completely disconnected, and then remove the plastic bracket.
    • Remove the 22 screws on the bezel.
    • Remove the left and right brackets; the left has 16 screws and the right has 15 screws.
    • The three different torx screws used are T3, T4, and T5.
    댓글 쓰기
  6. Microsoft Surface Pro 2 Audio Ports Replacement: 6 단계, 이미지 3개 중 1개 Microsoft Surface Pro 2 Audio Ports Replacement: 6 단계, 이미지 3개 중 2개 Microsoft Surface Pro 2 Audio Ports Replacement: 6 단계, 이미지 3개 중 3개
    • Once the brackets are removed, set them aside.
    • The motherboard itself also has screws.
    • Remove the 25 screws of varying sizes that attach the motherboard to the back plate.
    • View the attached photo of a screw diagram to help keep track of your screws.
    댓글 쓰기
  7. Microsoft Surface Pro 2 Audio Ports Replacement: 7 단계, 이미지 3개 중 1개 Microsoft Surface Pro 2 Audio Ports Replacement: 7 단계, 이미지 3개 중 2개 Microsoft Surface Pro 2 Audio Ports Replacement: 7 단계, 이미지 3개 중 3개
    • You have now completely removed the motherboard, and it should look like the pictures shown.
    • Be sure to be cautious with all the connections with the cables on the motherboard.
    댓글 쓰기
  8. Microsoft Surface Pro 2 Audio Ports Replacement, Audio Ports: 8 단계, 이미지 2개 중 1개 Microsoft Surface Pro 2 Audio Ports Replacement, Audio Ports: 8 단계, 이미지 2개 중 2개
    • The entire assembly can be removed by taking out one final screw.
    • These screws as well as the ribbon were removed during the perquisite guide for removing the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Mathew B
회원 가입일: 09/19/16
323 평판
안내서 2개를 작성함
USF Tampa, Team 6-2, Remmell Fall 2016 USF Tampa, Team 6-2, Remmell Fall 2016 회원
USFT-REMMELL-F16S6G2
4 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 37
전체 시간: 1,838
