주요 콘텐츠로 건너뛰기
Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Disconnect the display board: 1 단계, 이미지 3개 중 1개 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Disconnect the display board: 1 단계, 이미지 3개 중 2개 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Disconnect the display board: 1 단계, 이미지 3개 중 3개
    • Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
  2. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 2 단계, 이미지 3개 중 1개 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 2 단계, 이미지 3개 중 2개 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to slide the display cables straight out of their sockets on the display board.
  3. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the display board: 3 단계, 이미지 3개 중 1개 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the display board: 3 단계, 이미지 3개 중 2개 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the display board: 3 단계, 이미지 3개 중 3개
    • Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
  4. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    • Remove the display board.
    • During reassembly, use a strong double-sided tape or a precut adhesive card to secure the display board. Clean off the old adhesive before applying new adhesive.
    • To ensure correct positioning, plug in both display connectors before adhering the board to the display.
  5. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Only the screen remains.
  6. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the heat sink shield: 6 단계, 이미지 2개 중 1개 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the heat sink shield: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
    • Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
    • Take care not to puncture the battery with the tweezers while working on this shield.
  7. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 7 단계, 이미지 3개 중 1개 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 7 단계, 이미지 3개 중 2개 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 7 단계, 이미지 3개 중 3개
    • Repeat the last step for each corner of the EMI shield covering the heat sink.
  8. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the heat sink shield.
  9. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the heat sink: 9 단계, 이미지 2개 중 1개 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the heat sink: 9 단계, 이미지 2개 중 2개
    • Remove the nine Torx screws securing the heat sink:
    • Five 2.6 mm-long T3 screws
    • Four 3.3 mm-long T5 screws
    • During reassembly, tighten the heat sink screws in the following criss-cross pattern, one turn at a time, until they're tight:
    • Screw 1
    • Screw 2
    • Screw 3
    • Screw 4
  10. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 10 단계, 이미지 3개 중 1개 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 10 단계, 이미지 3개 중 2개 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 10 단계, 이미지 3개 중 3개
  11. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Camera Tie Bar: 11 단계, 이미지 1개 중 1개
    • Remove the Torx T5 x 6mm screw connecting the black tie bar to the power button/volume control/speaker assembly.
  12. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the remaining three Torx T5 x 4.5mm screws holding down the camera tie bar.
  13. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 13 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Disconnect the small ribbon cable connecting the camera tie bar to the motherboard by pulling up with tweezers.
  14. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 14 단계, 이미지 1개 중 1개
    • Lift the camera tie bar off of the device.
  15. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Power Button, Volume Buttons, and Left Speaker Assembly: 15 단계, 이미지 1개 중 1개
    • Use a Torx T5 to remove the two 4.5mm silver screws on the power button/volume control/speaker assembly.
  16. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 16 단계, 이미지 2개 중 1개 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 16 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Disconnect the small ribbon attaching the assembly to the motherboard by lifting up with tweezers.
    • Disconnect the black and red cable connector by lifting up with tweezers.
  17. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: 17 단계, 이미지 1개 중 1개
    • Pull the assembly to the left with hands and lift up to remove.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Kaden Foster
회원 가입일: 10/02/17
897 평판
안내서 3개를 작성함
Cal Poly, Team S15-G3, Livingston Fall 2017 Cal Poly, Team S15-G3, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G3
3 회원들
안내서 17개를 작성함
1가이드 댓글
Hi,
Where can I purchase the power button assembly in the UK?
junaidpatel - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 2,966
