주요 콘텐츠로 건너뛰기
Microsoft Surface Pro X SSD Port Replacement
필요한 것
  1. Microsoft Surface Pro X SSD Port Replacement, Open the kickstand: 1 단계, 이미지 2개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Open the kickstand: 1 단계, 이미지 2개 중 2개
    • Make sure your Surface Pro X is turned off, and laying screen-side down on a soft surface.
    • After turning off your device, make sure to remove the SSD from the Surface before starting any repairs. This will disconnect the battery and prevent damage to the device.
    • Lift the kickstand to at least a 90° angle, so that it is perpendicular to the Surface's screen. The further you open the hinge, the easier it is to access the SSD and SIM card door.
  2. Microsoft Surface Pro X SSD Port Replacement, Open the SSD and SIM card door: 2 단계, 이미지 2개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Open the SSD and SIM card door: 2 단계, 이미지 2개 중 2개
    • Insert a SIM card eject tool or a paperclip into the small hole in the bottom right corner of the SSD and SIM card door, located near the bottom right corner of the Surface.
    • Press firmly to open the door.
  3. Microsoft Surface Pro X SSD Port Replacement, Remove the SSD and SIM card door: 3 단계, 이미지 1개 중 1개
  4. Microsoft Surface Pro X SSD Port Replacement, Remove the SSD screw: 4 단계, 이미지 1개 중 1개
    • Use a T3 Torx screwdriver to remove the 2.4 mm screw securing the SSD.
  5. Microsoft Surface Pro X SSD Port Replacement, Remove the SSD: 5 단계, 이미지 3개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Remove the SSD: 5 단계, 이미지 3개 중 2개 Microsoft Surface Pro X SSD Port Replacement, Remove the SSD: 5 단계, 이미지 3개 중 3개
    • Use your finger or a spudger to lift the SSD just enough that it clears the edges of its recess.
    • Don't lift the SSD more than you have to—doing so may damage the SSD or its socket.
    • Gently pull the SSD straight out of its socket.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
  6. Microsoft Surface Pro X SSD Port Replacement, Tape the screen: 6 단계, 이미지 3개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Tape the screen: 6 단계, 이미지 3개 중 2개 Microsoft Surface Pro X SSD Port Replacement, Tape the screen: 6 단계, 이미지 3개 중 3개
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    • Lay overlapping strips of clear packing tape over the Surface’s display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
  7. Microsoft Surface Pro X SSD Port Replacement, Apply a suction cup to the screen: 7 단계, 이미지 2개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Apply a suction cup to the screen: 7 단계, 이미지 2개 중 2개
    • Wear safety glasses during the screen removal procedure in case the glass shatters while you're working.
    • There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to work slowly and be extremely careful while slicing through the adhesive.
    • Place your tablet on your work surface so that the screen is facing up.
    • Apply a suction cup to the screen next to the right speaker grille.
  8. Microsoft Surface Pro X SSD Port Replacement, Secure the tablet: 8 단계, 이미지 1개 중 1개
    • Place your hand on the screen next to the suction cup to secure the Surface while you lift up the screen.
  9. Microsoft Surface Pro X SSD Port Replacement, Create a gap between the screen and frame: 9 단계, 이미지 3개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Create a gap between the screen and frame: 9 단계, 이미지 3개 중 2개 Microsoft Surface Pro X SSD Port Replacement, Create a gap between the screen and frame: 9 단계, 이미지 3개 중 3개
    • Don't insert the opening pick more than 3 mm while cutting through the adhesive on the right, bottom, and left edge.
    • Lift up on the suction cup to create a gap between the screen and the frame.
    • The gap only needs to be wide enough to slide in an opening pick.
    • Insert an opening pick about 2 mm into the gap. Leave the opening pick in the gap to prevent it from resealing.
  10. Microsoft Surface Pro X SSD Port Replacement, Cut through the screen adhesive: 10 단계, 이미지 2개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Cut through the screen adhesive: 10 단계, 이미지 2개 중 2개
    • Insert a second opening pick into the gap between the screen and the frame.
    • Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
    • Leave this opening pick in the right edge to prevent the adhesive from resealing.
  11. Microsoft Surface Pro X SSD Port Replacement: 11 단계, 이미지 3개 중 1개 Microsoft Surface Pro X SSD Port Replacement: 11 단계, 이미지 3개 중 2개 Microsoft Surface Pro X SSD Port Replacement: 11 단계, 이미지 3개 중 3개
    • Don't insert the pick more than 3 mm while cutting through the screen adhesive on the bottom edge or you may damage delicate components on the screen.
    • Insert a third opening pick into the bottom right corner and slide it around the corner toward the bottom edge.
  12. Microsoft Surface Pro X SSD Port Replacement: 12 단계, 이미지 2개 중 1개 Microsoft Surface Pro X SSD Port Replacement: 12 단계, 이미지 2개 중 2개
    • Slide the pick along the bottom edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the bottom edge to prevent the adhesive from resealing.
  13. Microsoft Surface Pro X SSD Port Replacement: 13 단계, 이미지 3개 중 1개 Microsoft Surface Pro X SSD Port Replacement: 13 단계, 이미지 3개 중 2개 Microsoft Surface Pro X SSD Port Replacement: 13 단계, 이미지 3개 중 3개
    • Insert a fourth opening pick into the bottom left corner and slide it around the corner toward the left edge.
    • Slide the pick along the left edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the left edge to prevent the adhesive from resealing.
  14. Microsoft Surface Pro X SSD Port Replacement: 14 단계, 이미지 3개 중 1개 Microsoft Surface Pro X SSD Port Replacement: 14 단계, 이미지 3개 중 2개 Microsoft Surface Pro X SSD Port Replacement: 14 단계, 이미지 3개 중 3개
    • Don't insert the opening pick more than 10 mm while cutting through the adhesive on the top edge. Don't insert the pick more than 3 mm near the speaker grille.
    • Insert a fifth opening pick into the top left corner and slide it around the corner toward the top edge.
    • Slide the pick along the top edge of the Surface to cut through the screen adhesive.
  15. Microsoft Surface Pro X SSD Port Replacement, Open the Surface: 15 단계, 이미지 3개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Open the Surface: 15 단계, 이미지 3개 중 2개 Microsoft Surface Pro X SSD Port Replacement, Open the Surface: 15 단계, 이미지 3개 중 3개
    • Do not remove the screen yet. It is still connected to the motherboard by the display cable. Keep the screen as close as possible to the Surface's frame to avoid straining the display cable.
    • Avoid hitting the battery with the screen during this procedure. A punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Lift up the top edge of the screen so that it is at a 30° angle with the frame.
    • If you encounter any resistance, stop and check that all the adhesive is separated. Use an opening pick to cut through any remaining adhesive.
    • Rotate the screen so that its bottom edge is in the middle of the frame. The screen should be perpendicular to the frame.
    • Rotate the screen 90° so that it is facing down. Place the screen on the frame.
  16. Microsoft Surface Pro X SSD Port Replacement, Remove the display cable shield: 16 단계, 이미지 3개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Remove the display cable shield: 16 단계, 이미지 3개 중 2개 Microsoft Surface Pro X SSD Port Replacement, Remove the display cable shield: 16 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Insert a tine of a pair of pointed tweezers under the bottom right corner of the display cable shield (where the display cable is oriented down).
    • Lift up the corner to detach it from the screen.
  17. Microsoft Surface Pro X SSD Port Replacement: 17 단계, 이미지 2개 중 1개 Microsoft Surface Pro X SSD Port Replacement: 17 단계, 이미지 2개 중 2개
    • Repeat the previous step for the bottom right corner.
  18. Microsoft Surface Pro X SSD Port Replacement: 18 단계, 이미지 1개 중 1개
    • Remove the display cable shield from the screen.
    • If the display cable shield isn't completely detached from the screen, pry up additional areas around the edges of the shield.
  19. Microsoft Surface Pro X SSD Port Replacement, Disconnect the screen: 19 단계, 이미지 2개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Disconnect the screen: 19 단계, 이미지 2개 중 2개
    • Insert the pointed end of a spudger under the right side of the display cable press connector.
    • Lift up the right side of the press connector to detach it from the display cable socket on the screen.
  20. Microsoft Surface Pro X SSD Port Replacement: 20 단계, 이미지 2개 중 1개 Microsoft Surface Pro X SSD Port Replacement: 20 단계, 이미지 2개 중 2개
    • Repeat the previous step on the left side of the display cable connector to fully disconnect it from the screen.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. Microsoft Surface Pro X SSD Port Replacement, Remove the screen: 21 단계, 이미지 1개 중 1개
    • Remove the screen from the frame.
  22. Microsoft Surface Pro X SSD Port Replacement, Speaker grille information: 22 단계, 이미지 2개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Speaker grille information: 22 단계, 이미지 2개 중 2개
    • The left and right speaker grilles may be attached to the Surface's frame or the screen.
    • If you are going to replace a speaker grille that is attached to the frame, follow these steps to remove it:
    • Use an opening pick to cut through the adhesive under the grille.
    • Remove the speaker grille.
    • Repeat for the other speaker grille.
  23. Microsoft Surface Pro X SSD Port Replacement: 23 단계, 이미지 2개 중 1개 Microsoft Surface Pro X SSD Port Replacement: 23 단계, 이미지 2개 중 2개
    • If you are going to replace or transfer a speaker grille that is attached to the screen, follow these steps to remove it:
  24. Microsoft Surface Pro X SSD Port Replacement, Screen adhesive information: 24 단계, 이미지 3개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Screen adhesive information: 24 단계, 이미지 3개 중 2개 Microsoft Surface Pro X SSD Port Replacement, Screen adhesive information: 24 단계, 이미지 3개 중 3개
    • If you are going to replace the screen adhesive, follow these steps:
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the adhesive.
    • Use a cotton swab or the flat end of a spudger to scrape away the adhesive.
    • Use a lint-free cloth or coffee filter to wipe away any remaining adhesive.
    • Allow the surface to dry completely before applying replacement adhesive.
    • Apply new adhesive strips or pre-cut adhesive to the frame where the old screen adhesive was located.
  25. Microsoft Surface Pro X SSD Port Replacement, Lift the corner of the shield: 25 단계, 이미지 2개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Lift the corner of the shield: 25 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Take care not to puncture or bend the battery with any tools while removing the SSD port—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Insert one tine of a pair of pointed tweezers under the top left corner of the SSD port connector's shield (where the cable is oriented down).
    • Lift up the corner to detach it from the frame.
  26. Microsoft Surface Pro X SSD Port Replacement, Remove the shield: 26 단계, 이미지 2개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Remove the shield: 26 단계, 이미지 2개 중 2개
    • Remove the SSD port connector's shield.
    • If the shield isn't completely detached from the frame, pry up additional areas on the edges of the shield.
  27. Microsoft Surface Pro X SSD Port Replacement, Remove the SSD port sticker: 27 단계, 이미지 2개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Remove the SSD port sticker: 27 단계, 이미지 2개 중 2개
    • If you are going to reinstall this sticker during reassembly, try to keep it as intact as possible.
    • Use the pointed end of a spudger to lift up a corner of the black sticker covering the SSD port.
  28. Microsoft Surface Pro X SSD Port Replacement: 28 단계, 이미지 2개 중 1개 Microsoft Surface Pro X SSD Port Replacement: 28 단계, 이미지 2개 중 2개
    • Remove the SSD port sticker.
  29. Microsoft Surface Pro X SSD Port Replacement, Disconnect the SSD port: 29 단계, 이미지 2개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Disconnect the SSD port: 29 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to disconnect the SSD port's press connector from its socket.
  30. Microsoft Surface Pro X SSD Port Replacement, Disconnect the SIM card reader: 30 단계, 이미지 2개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Disconnect the SIM card reader: 30 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to disconnect the SIM card reader's press connector from its socket.
  31. Microsoft Surface Pro X SSD Port Replacement, Remove the SSD port screws: 31 단계, 이미지 1개 중 1개
    • Use a T3 Torx screwdriver to remove the two 2.5 mm screws securing the SSD port.
  32. Microsoft Surface Pro X SSD Port Replacement, Remove the SSD port: 32 단계, 이미지 2개 중 1개 Microsoft Surface Pro X SSD Port Replacement, Remove the SSD port: 32 단계, 이미지 2개 중 2개
    • The SSD port cable is lightly adhered to the frame. If the adhesive is too difficult to cut through, continue to the next step for additional removal instructions.
    • Use an opening pick to cut through the adhesive under the SIM card reader socket.
  33. Microsoft Surface Pro X SSD Port Replacement: 33 단계, 이미지 1개 중 1개
    • If the adhesive under the SIM card reader socket is too difficult to cut through, follow these steps to loosen the adhesive:
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the SIM card reader socket to loosen the adhesive underneath.
    • Wait thirty seconds for the isopropyl alcohol to weaken the adhesive.
  34. Microsoft Surface Pro X SSD Port Replacement: 34 단계, 이미지 1개 중 1개
    • Remove the SSD port from the frame.
    • If there's any alcohol solution remaining in the Surface, carefully wipe it off with a lint-free cloth or allow it to air dry before installing your SSD port.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Microsoft Surface Pro X Answers community for help.
작성자
1다른 기여자 명과 함께
Kyle Smith
회원 가입일: 02/01/21
49,220 평판
안내서 123개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 26
전체 시간: 1,570
