주요 콘텐츠로 건너뛰기
Microsoft Zune HD Lower Rear Panel Replacement
필요한 것
  1. Microsoft Zune HD Lower Rear Panel Replacement, Upper Rear Panel: 1 단계, 이미지 1개 중 1개
    • Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
  2. Microsoft Zune HD Lower Rear Panel Replacement: 2 단계, 이미지 2개 중 1개 Microsoft Zune HD Lower Rear Panel Replacement: 2 단계, 이미지 2개 중 2개
    • Slightly rotate the top edge of the upper rear panel away from the Zune.
    • Lift the upper rear panel straight up off the black plastic lower rear panel.
  3. Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: 3 단계, 이미지 2개 중 1개 Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: 3 단계, 이미지 2개 중 2개
    • Insert a small Zune opening tool into the gap between the logic board and one side of the black plastic lower rear panel.
    • Carefully twist the Zune opening tool to pop the lower rear panel off the clips attaching it to the Zune.
    • Repeat this process for the other side of the lower rear panel.
  4. Microsoft Zune HD Lower Rear Panel Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully slide the lower rear panel away from the Zune.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Walter Galan
701,433 평판
안내서 1,203개를 작성함
1 Guide Comment
I followed these instructions and now that lower cover will not snap back in place 😒
Robert Rank - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 13
전체 시간: 3,192
