주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microtek ScanMaker 5900 New Locking Mechanism Replacement
필요한 것
    1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: 1 단계, 이미지 3개 중 1개 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: 1 단계, 이미지 3개 중 2개 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: 1 단계, 이미지 3개 중 3개
      • Loosen the screws on the serial port by turning them counter clockwise by hand.
      • After loosening the screws, pull the serial port out.
      댓글 쓰기
    2. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: 2 단계, 이미지 3개 중 1개 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: 2 단계, 이미지 3개 중 2개 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: 2 단계, 이미지 3개 중 3개
      • Lift lid to its vertical position.
      • Pull lid straight up to remove it from the scanner.
      댓글 쓰기
    1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: 3 단계, 이미지 3개 중 1개 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: 3 단계, 이미지 3개 중 2개 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: 3 단계, 이미지 3개 중 3개
      • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
      댓글 쓰기
    2. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: 4 단계, 이미지 3개 중 1개 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: 4 단계, 이미지 3개 중 2개 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: 4 단계, 이미지 3개 중 3개
      • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
      • Go all the way along the chassis until you can lift the upper lid.
      댓글 쓰기
    3. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: 5 단계, 이미지 3개 중 1개 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: 5 단계, 이미지 3개 중 2개 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: 5 단계, 이미지 3개 중 3개
      • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
      • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
      • Grab the ribbon cable and gently pull it out of its slot with your fingers.
      • The upper lid can now safely be removed from the bottom lid.
      댓글 쓰기
    1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: 6 단계, 이미지 3개 중 1개 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: 6 단계, 이미지 3개 중 2개 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: 6 단계, 이미지 3개 중 3개
      • Locate the locking mechanism in the front left hand corner of the device.
      • Gently push on it until it becomes loose.
      • Rotate and jiggle it until it comes out the bottom of the scanner.
      • Find a replacement locking mechanism and insert it into the scanner.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Taylor Nesheim
회원 가입일: 10/11/11
59 평판
안내서 7개를 작성함
Cal Poly, Team 6-9, Regan Fall 2011 Cal Poly, Team 6-9, Regan Fall 2011 회원
CPSU-REGAN-F11S6G9
2 회원들
안내서 99개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 37
전체 시간: 1,768
