주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement
필요한 것
    1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: 1 단계, 이미지 3개 중 1개 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: 1 단계, 이미지 3개 중 2개 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: 1 단계, 이미지 3개 중 3개
      • Loosen the screws on the serial port by turning them counter clockwise by hand.
      • After loosening the screws, pull the serial port out.
      댓글 쓰기
    2. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: 2 단계, 이미지 3개 중 1개 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: 2 단계, 이미지 3개 중 2개 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: 2 단계, 이미지 3개 중 3개
      • Lift lid to its vertical position.
      • Pull lid straight up to remove it from the scanner.
      댓글 쓰기
    1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: 3 단계, 이미지 3개 중 1개 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: 3 단계, 이미지 3개 중 2개 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: 3 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Notice that there are two plastic tabs that need to be pushed in to remove the plastic covering.
      • Use tweezers to push these tabs in.
      • Gently pull the plastic covering off of the upper lid.
      댓글 쓰기
    2. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: 4 단계, 이미지 3개 중 1개 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: 4 단계, 이미지 3개 중 2개 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: 4 단계, 이미지 3개 중 3개
      • Grab the plastic wire housing near the serial port.
      • Gently pull and jiggle the wire housing until it comes free from the circuit board.
      댓글 쓰기
    3. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: 5 단계, 이미지 2개 중 1개 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: 5 단계, 이미지 2개 중 2개
      • Gently lift up the bulbs and remove the wires from the plastic.
      • After completely freeing the bulbs, buy new ones and replace.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Taylor Nesheim
회원 가입일: 10/11/11
59 평판
안내서 7개를 작성함
Cal Poly, Team 6-9, Regan Fall 2011 Cal Poly, Team 6-9, Regan Fall 2011 회원
CPSU-REGAN-F11S6G9
2 회원들
안내서 99개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 36
전체 시간: 1,553
