주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Midiman Oxygen 8 Keys Replacement
필요한 것
    1. Midiman Oxygen 8 Keys Replacement, Midiman Oxygen 8 Backplate Disassembly: 1 단계, 이미지 2개 중 1개 Midiman Oxygen 8 Keys Replacement, Midiman Oxygen 8 Backplate Disassembly: 1 단계, 이미지 2개 중 2개
      • Remove the 8 mm M3 Phillips head self tapping machine screws.
      • Several of the screws are in narrow, deep sockets; make sure to use an appropriate screw driver to remove them so as not to damage the cover during removal.
      • Remove all 13 of the back plate screws.
      댓글 쓰기
    2. Midiman Oxygen 8 Keys Replacement: 2 단계, 이미지 2개 중 1개 Midiman Oxygen 8 Keys Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the two highlighted 10 mm M3 galvanized machine screws using the J1 head fro the iFixit Tool Kit or a comparable tool.
      댓글 쓰기
    3. Midiman Oxygen 8 Keys Replacement: 3 단계, 이미지 3개 중 1개 Midiman Oxygen 8 Keys Replacement: 3 단계, 이미지 3개 중 2개 Midiman Oxygen 8 Keys Replacement: 3 단계, 이미지 3개 중 3개
      • Removal of Ribbon Cables
      • Prior to removal, note, mark, or take photo’s of the position of all connectors. Specifically note the side that the red wire is on, as ribbon cables are polarized cables that must be re-installed correctly. Installing the cables backwards may cause damage to the device or significantly hinder the troubleshooting process.
      • To separate the back plate, remove all five cables that connect to the motherboard but do not originate from the back plate; the key assembly, LCD circuit, rotor tuning circuit, and the pitch and modulator circuits. None of these cables require tools to remove, simply apply firm upward pressure to remove them.
      댓글 쓰기
    4. Midiman Oxygen 8 Keys Replacement: 4 단계, 이미지 2개 중 1개 Midiman Oxygen 8 Keys Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the key assembly from the key board.
      • What remains is the back plate and the top plate assemblies.
      댓글 쓰기
    1. Midiman Oxygen 8 Keys Replacement, Keys: 5 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • The keys are retained via a tension spring. The removal of these springs is simple using the hooked needle point tweezers from the IFixit Toolkit.
      댓글 쓰기
    2. Midiman Oxygen 8 Keys Replacement: 6 단계, 이미지 2개 중 1개 Midiman Oxygen 8 Keys Replacement: 6 단계, 이미지 2개 중 2개
      • To remove, simply insert one of the tweezer ends through the opening at the end of the spring.
      • Press the end between the spring windings after the windings start to reduce in size towards the inside of the spring.
      댓글 쓰기
    3. Midiman Oxygen 8 Keys Replacement: 7 단계, 이미지 1개 중 1개
      • Next, clasp the spring windings with the tweezers and gently apply tension outward.
      • The spring should thin slightly and be easily raised up and out of the retaining keyway.
      • This will free the key from the keyboard assembly for repair or replacement.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Scott Miller
회원 가입일: 10/04/16
437 평판
안내서 4개를 작성함
USF Tampa, Team 1-6, Sullivan Fall 2016 USF Tampa, Team 1-6, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S1G6
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 29
전체 시간: 1,172
