주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mill Cutter Paper Stripper Replacement
필요한 것
    1. Mill Cutter Paper Stripper Replacement, Mill cutter paper stripper set and stripper guide set: 1 단계, 이미지 1개 중 1개
      • Unplug the shredder from the wall electrical outlet.
      • Remove the shredder from its catch basket and place it face down on a flat surface.
      댓글 쓰기
    2. Mill Cutter Paper Stripper Replacement: 2 단계, 이미지 3개 중 1개 Mill Cutter Paper Stripper Replacement: 2 단계, 이미지 3개 중 2개 Mill Cutter Paper Stripper Replacement: 2 단계, 이미지 3개 중 3개
      • Locate the seven case screws and remove them with a Phillips screwdriver. The screws are identified by the seven marked circles. The screws are 15 mm in length and the head diameter is 5 mm.
      • Remove the manufacturer’s label in order to get to one of the hidden screws, if applicable.
      댓글 쓰기
    3. Mill Cutter Paper Stripper Replacement: 3 단계, 이미지 2개 중 1개 Mill Cutter Paper Stripper Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the screws connecting the stripper guide and the base of the shredder's housing unit with a Phillips screwdriver. The diameter head and screws are 10 mm in length.
      댓글 쓰기
    4. Mill Cutter Paper Stripper Replacement: 4 단계, 이미지 2개 중 1개 Mill Cutter Paper Stripper Replacement: 4 단계, 이미지 2개 중 2개
      • Once all of the screws have been removed, pull the casing apart.
      • Remove the stripper guide from the housing unit.
      • Use caution to prevent the trigger guard from falling apart.
      댓글 쓰기
    5. Mill Cutter Paper Stripper Replacement: 5 단계, 이미지 3개 중 1개 Mill Cutter Paper Stripper Replacement: 5 단계, 이미지 3개 중 2개 Mill Cutter Paper Stripper Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the e-clips from the gears on the left side with a flathead screwdriver.
      • Remove screws from the gear box cover on the right side with a Phillips screwdriver. The screws are identified by the two marked circles. The screws are 7 mm in length and the head diameter is 3 mm.
      댓글 쓰기
    6. Mill Cutter Paper Stripper Replacement: 6 단계, 이미지 3개 중 1개 Mill Cutter Paper Stripper Replacement: 6 단계, 이미지 3개 중 2개 Mill Cutter Paper Stripper Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the gears from both sides.
      • If the gears are hard to remove, use a flathead screwdriver to help remove them. The gears also may be greasy so place them on a paper towel or newspaper.
      • Remove the screws from the gearbox side plate with Phillips screwdriver to get to the gears. The screws are 7 mm in length and the head diameter is 3 mm.
      댓글 쓰기
    7. Mill Cutter Paper Stripper Replacement: 7 단계, 이미지 2개 중 1개 Mill Cutter Paper Stripper Replacement: 7 단계, 이미지 2개 중 2개
      • Replace the mill cutter paper stripper set and stripper guide set.
      • Use protective gloves as the blades are very sharp.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Takisha Parrish
회원 가입일: 01/21/18
175 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 39
전체 시간: 2,003
