주요 콘텐츠로 건너뛰기
Minolta Dimage Xt Flash Capacitor Replacement
필요한 것
  1. Minolta Dimage Xt Flash Capacitor Replacement, Casing: 1 단계, 이미지 1/3 Minolta Dimage Xt Flash Capacitor Replacement, Casing: 1 단계, 이미지 2/3 Minolta Dimage Xt Flash Capacitor Replacement, Casing: 1 단계, 이미지 3/3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Flash Capacitor Replacement: 2 단계, 이미지 1/3 Minolta Dimage Xt Flash Capacitor Replacement: 2 단계, 이미지 2/3 Minolta Dimage Xt Flash Capacitor Replacement: 2 단계, 이미지 3/3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: 3 단계, 이미지 1/2 Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: 3 단계, 이미지 2/2
    • Caution: Touching the capacitor leads may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • On the front side of the camera, locate the flash battery holder.
    • Lift the housing and remove the battery.
    • After removing the battery, clip the wires and solder the replacement battery.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Qqq
회원 가입일: 03/11/13
19 평판
안내서 1개 작성함
댓글 한 개
Its a cap not a battery :D
Eigirdas Gedgaudas - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 22
전체 시간: 1,007
