주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Minolta Dimage Xt LCD Screen Disassembly
필요한 것
    1. Minolta Dimage Xt LCD Screen Disassembly, Casing: 1 단계, 이미지 3개 중 1개 Minolta Dimage Xt LCD Screen Disassembly, Casing: 1 단계, 이미지 3개 중 2개 Minolta Dimage Xt LCD Screen Disassembly, Casing: 1 단계, 이미지 3개 중 3개
      • Locate and remove the silver screws on each side of the camera.
      • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
      댓글 쓰기
    2. Minolta Dimage Xt LCD Screen Disassembly: 2 단계, 이미지 3개 중 1개 Minolta Dimage Xt LCD Screen Disassembly: 2 단계, 이미지 3개 중 2개 Minolta Dimage Xt LCD Screen Disassembly: 2 단계, 이미지 3개 중 3개
      • Then, carefully pry apart the front and back outer casing away from the internal components.
      • Be aware of the ribbon wire that will disconnect when the casing is detached.
      댓글 쓰기
    1. Minolta Dimage Xt LCD Screen Disassembly, LCD Screen: 3 단계, 이미지 1개 중 1개
      • The LCD screen has wires connecting it to the rest of the camera. A bracket holds the LCD in place, so there are no screws beyond this point.
      • The screen also has a ribbon wire connected at the bottom of the screen.
      댓글 쓰기
    2. Minolta Dimage Xt LCD Screen Disassembly: 4 단계, 이미지 2개 중 1개 Minolta Dimage Xt LCD Screen Disassembly: 4 단계, 이미지 2개 중 2개
      • Detach the connector at the bottom from the LCD screen.
      • Starting from the side or a corner gently slide the spudger underneath the screen.
      • Press the tip of the spudger down as far is you can and slowly pry the LCD screen away from the bracket.
      댓글 쓰기
    3. Minolta Dimage Xt LCD Screen Disassembly: 5 단계, 이미지 1개 중 1개
      • The screen is not detached. Wires are still connecting the screen to the camera at the bottom corners, but it is removed from the bracket.
      • Check to make sure the wires are connected, so it will receive proper power supply.
      • To remove the bracket from the LCD screen, remove two 1.5 mm screws using the Phillips #00 screwdriver.
      댓글 쓰기
결론
To install a new LCD screen you will have to reconnect the wires and properly place them in the bracket. Make sure to reattach the ribbon wire before finishing repairs.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Keith Sechrist
회원 가입일: 03/11/13
22 평판
안내서 2개를 작성함
Clemson, Team 12-4, Benson Spring 2013 Clemson, Team 12-4, Benson Spring 2013 회원
CLEM-BENSON-S13S12G4
3 회원들
안내서 14개를 작성함
1가이드 댓글
Great procedure, thank you.
Do you know where I can buy the LCD replacement part?
I have a Konica Minolta Dimage X1 8.0 MP
mscir - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 47
전체 시간: 1,898
