주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mirror Box Removal
필요한 것
  1. Mirror Box Removal, Remove film door: 1 단계, 이미지 1개 중 1개
    • Push down the latch to release the film door.
    댓글 쓰기
  2. Mirror Box Removal, Remove top cover screws: 2 단계, 이미지 3개 중 1개 Mirror Box Removal, Remove top cover screws: 2 단계, 이미지 3개 중 2개 Mirror Box Removal, Remove top cover screws: 2 단계, 이미지 3개 중 3개
    • Remove two 7.5 mm #00 screws.
    • Remove one 9.0 mm #00 screw.
    • Remove one 13.5 mm #00 screw from inside the battery compartment.
    댓글 쓰기
  3. Mirror Box Removal, Remove top cover screws: 3 단계, 이미지 3개 중 1개 Mirror Box Removal, Remove top cover screws: 3 단계, 이미지 3개 중 2개 Mirror Box Removal, Remove top cover screws: 3 단계, 이미지 3개 중 3개
    • Push the button to pop up the flash.
    • Remove one 3.5 mm #00 screw.
    • Remove one 5.5 mm #00 screw.
    댓글 쓰기
  4. Mirror Box Removal, Lift top cover: 4 단계, 이미지 1개 중 1개
    • Carefully lift the top cover away from the body to access wired connections.
    • The top cover is still connected in several locations.
    댓글 쓰기
  5. Mirror Box Removal, Access flash connections: 5 단계, 이미지 2개 중 1개 Mirror Box Removal, Access flash connections: 5 단계, 이미지 2개 중 2개
    • Peel back the corner of the rubber grip.
    • Remove the small plastic cover.
    • Be careful not to short the wires before the flash capacitors have been properly discharged.
    댓글 쓰기
  6. Mirror Box Removal, Discharge flash capacitors: 6 단계, 이미지 1개 중 1개
    • Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
    댓글 쓰기
  7. Mirror Box Removal, Disconnect right flex cable: 7 단계, 이미지 1개 중 1개
    • Carefully lift the sides of the white latch.
    • Hold the flex PCB on the camera body in place as you lift to prevent damaging the flex.
    댓글 쓰기
  8. Mirror Box Removal, Disconnect left flex cable: 8 단계, 이미지 1개 중 1개
    • Desolder the red wire.
    댓글 쓰기
  9. Mirror Box Removal, Desolder flash connections: 9 단계, 이미지 2개 중 1개 Mirror Box Removal, Desolder flash connections: 9 단계, 이미지 2개 중 2개
    • Desolder blue, black, brown and green wires.
    • Remove the loose shim washer if present.
    댓글 쓰기
  10. Mirror Box Removal, Desolder the flash flex cable: 10 단계, 이미지 2개 중 1개 Mirror Box Removal, Desolder the flash flex cable: 10 단계, 이미지 2개 중 2개
    • Remove the piece of cellophane tape covering the flex connections.
    • Desolder flex connetions.
    댓글 쓰기
  11. Mirror Box Removal, Remove bottom cover: 11 단계, 이미지 3개 중 1개 Mirror Box Removal, Remove bottom cover: 11 단계, 이미지 3개 중 2개 Mirror Box Removal, Remove bottom cover: 11 단계, 이미지 3개 중 3개
    • Use isopropyl alcohol to soften the adhesive under the country plate and remove.
    • Remove one 5mm #00 screw.
    • Remove one 7.5mm #00 screw.
    • Remove two 4.5mm #00 screws.
    • Remove one 5.5mm #00 screw.
    • Remove the plastic frame around the accessory grip contacts.
    • Reassembly Note: The camera can be checked for functionality at this point. Install the rear door, insert a fresh pair of batteries and try to fire the shutter.
    댓글 쓰기
  12. Mirror Box Removal, Remove front left cover: 12 단계, 이미지 1개 중 1개
    • Remove one 4.0 mm #00 screw.
    • Remove left cover.
    댓글 쓰기
  13. Mirror Box Removal, Remove front cover: 13 단계, 이미지 1개 중 1개
    • Remove front cover.
    댓글 쓰기
  14. Mirror Box Removal, Unscrew front right cover: 14 단계, 이미지 3개 중 1개 Mirror Box Removal, Unscrew front right cover: 14 단계, 이미지 3개 중 2개 Mirror Box Removal, Unscrew front right cover: 14 단계, 이미지 3개 중 3개
    • Remove one 6.0 mm #00 screw.
    • Remove two 3.5 mm #00 screws.
    • Remove one 5.0 mm #00 screw.
    • Remove the strap lug.
    댓글 쓰기
  15. Mirror Box Removal, Remove the front right cover: 15 단계, 이미지 1개 중 1개
    • Carefully pull the right panel away from the body. It is still attached.
    • Desolder the flex connections.
    댓글 쓰기
  16. Mirror Box Removal, Remove bottom plate: 16 단계, 이미지 3개 중 1개 Mirror Box Removal, Remove bottom plate: 16 단계, 이미지 3개 중 2개 Mirror Box Removal, Remove bottom plate: 16 단계, 이미지 3개 중 3개
    • Remove the protective mask around the accessory grip contacts.
    • Lift the flex contacts free of their retaining posts. Use isopropyl alcohol to soften any glue or tape that is present.
    • Remove four 4.0 mm #00 screws (standard metric threads).
    • Remove four 4.0 mm #00 screws (plastic threads).
    댓글 쓰기
  17. Mirror Box Removal, Desolder speaker: 17 단계, 이미지 1개 중 1개
    • Desolder the black and red wires for the speaker.
    댓글 쓰기
  18. Mirror Box Removal, Desolder connections to bottom flex circuit: 18 단계, 이미지 3개 중 1개 Mirror Box Removal, Desolder connections to bottom flex circuit: 18 단계, 이미지 3개 중 2개 Mirror Box Removal, Desolder connections to bottom flex circuit: 18 단계, 이미지 3개 중 3개
    • Desolder the white and pink wires.
    • Desolder the red, black and gray wires.
    • Desolder the red, black and orange wires.
    • Desolder the white and blue wires.
    • Carefully peal the tape away and detach the red, black, white and blue wires from the glue. Use isopropyl alcohol to soften the glue if necessary.
    • Desolder the flex connection.
    댓글 쓰기
  19. Mirror Box Removal, Desolder connections to top flex circuit: 19 단계, 이미지 3개 중 1개 Mirror Box Removal, Desolder connections to top flex circuit: 19 단계, 이미지 3개 중 2개 Mirror Box Removal, Desolder connections to top flex circuit: 19 단계, 이미지 3개 중 3개
    • Desolder red, black, gray and orange wires.
    • Desolder flex contacts.
    • Disconnect flex connector.
    • Desolder yellow and purple wires.
    댓글 쓰기
  20. Mirror Box Removal, Desolder connections to top flex circuit: 20 단계, 이미지 2개 중 1개 Mirror Box Removal, Desolder connections to top flex circuit: 20 단계, 이미지 2개 중 2개
    • Desolder black wire.
    • Desolder battery contact tab.
    댓글 쓰기
  21. Mirror Box Removal, Desolder flex connection above the lens mount: 21 단계, 이미지 2개 중 1개 Mirror Box Removal, Desolder flex connection above the lens mount: 21 단계, 이미지 2개 중 2개
    • Desolder flex connection and remove from retention posts. Use isopropyl alcohol to soften the glue if necessary.
    • Carefully peal the flex cable from the surface of the flash capacitor. Use isopropyl alcohol to soften the glue if necessary.
    댓글 쓰기
  22. Mirror Box Removal, Remove eye piece assembly: 22 단계, 이미지 2개 중 1개 Mirror Box Removal, Remove eye piece assembly: 22 단계, 이미지 2개 중 2개
    • Remove two 5.0 mm #00 screws.
    • Remove the eye piece.
    • The outer cover of the eye piece is only attached with double sided tape and may come away on its own. Make sure the entire eye piece unit is removed before proceeding.
    댓글 쓰기
  23. Mirror Box Removal, Remove lens release switch: 23 단계, 이미지 2개 중 1개 Mirror Box Removal, Remove lens release switch: 23 단계, 이미지 2개 중 2개
    • Remove one #00 screw.
    • Reassembly Note: Ensure that the lower contact catches on the plastic nub and that the contact is open when the lens release button is not pressed.
    댓글 쓰기
  24. Mirror Box Removal, Flip the mirror up: 24 단계, 이미지 2개 중 1개 Mirror Box Removal, Flip the mirror up: 24 단계, 이미지 2개 중 2개
    • Rotate the black gear downward until the mirror flips up into the taking position. It may take several turns.
    • Some failures will result in the mirror appearing to be in the upper position but the internal mechanism is still "down". The mechanism needs to be moved to release the mirror box.
    댓글 쓰기
  25. Mirror Box Removal, Detach flex circuit: 25 단계, 이미지 2개 중 1개 Mirror Box Removal, Detach flex circuit: 25 단계, 이미지 2개 중 2개
    • Remove one 4.0 mm screw.
    • Gently lift the flex circuit away from the housing.
    댓글 쓰기
  26. Mirror Box Removal, Unscrew the mirror box: 26 단계, 이미지 2개 중 1개 Mirror Box Removal, Unscrew the mirror box: 26 단계, 이미지 2개 중 2개
    • Remove two 6.5 mm #0 screws.
    • Remove one 8.0 mm #0 screw.
    • Remove one 4.5 mm #00 screw.
    • Remove two 2.5 mm #00 screws.
    • There may be a shim washer here. Remove if loose.
    • Remove one 4.0 mm #00 shoulder screw.
    댓글 쓰기
  27. Mirror Box Removal, Remove the mirror box: 27 단계, 이미지 2개 중 1개 Mirror Box Removal, Remove the mirror box: 27 단계, 이미지 2개 중 2개
    • Push the mirror box up to free it from the bottom plate.
    • Lift the left side of the mirror box and rotate it up and out of the camera body.
    • Be gentle. Keep an eye out for any snagged flex cables or wires. The right side of the mirror box is still connected to the camera body and it cannot be completely removed.
    • Check for shim washers at the mount locations. Note location and remove if loose.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Sam Gustafson
회원 가입일: 09/01/22
11,000 평판
안내서 78개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 45
전체 시간: 668
