주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Monster DNA Wire Replacement
필요한 것
    1. Monster DNA Wire Replacement, Wire: 1 단계, 이미지 1개 중 1개
      • Take off the ear cushions by pulling on the sides.
      댓글 쓰기
    2. Monster DNA Wire Replacement: 2 단계, 이미지 1개 중 1개
      • Use a Phillips #2 screwdriver to unscrew the three 5mm screws that secure the speaker cover.
      댓글 쓰기
    3. Monster DNA Wire Replacement: 3 단계, 이미지 1개 중 1개
      • Use a plastic opening tool or a metal spudger to pry off the plate
      • Be careful as too much force may cause damage to your headphones.
      댓글 쓰기
    4. Monster DNA Wire Replacement: 4 단계, 이미지 1개 중 1개
      • Once the loose wire or wires are located on the back of the speaker, use a soldering iron to attach the loose wire back onto the speaker.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Kevin Costello
회원 가입일: 03/22/17
231 평판
안내서 2개를 작성함
UMass Dartmouth, Team S4-G5, Julie Spring 2017 UMass Dartmouth, Team S4-G5, Julie Spring 2017 회원
UMASSD-JULIE-S17S4G5
4 회원들
안내서 12개를 작성함
2가이드 댓글
any ways on being able to know which side its on in particular without having to open both sides?
Finnlay Worchurst - 답글 공유
I broke the plate which holds the ear muffs on, by following these directions.
On Step 3, you have the spudger in the wrong location. You are supposed to put the prying bar or spudger before or after the silver ring which acts as a spacer for the speaker housing. I like to pry in the space between the silver ring and the audio jack.
Pics look good but you will have replace the one in step 3 showing the correct location to pry from. Others too will brake the same ring I did hence your warning about damage to the headphones if applying too much pressure.
Dan
Dan Daley - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 52
전체 시간: 4,448
