주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motion Computing LE1600 Button Assembly Replacement
필요한 것
    1. Motion Computing LE1600 Button Assembly Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Turn the device so the screen is facing down.
      댓글 쓰기
    2. Motion Computing LE1600 Button Assembly Replacement: 2 단계, 이미지 2개 중 1개 Motion Computing LE1600 Button Assembly Replacement: 2 단계, 이미지 2개 중 2개
      • Slide the battery lock switch next to the power slider to the unlocked position.
      댓글 쓰기
    3. Motion Computing LE1600 Button Assembly Replacement: 3 단계, 이미지 3개 중 1개 Motion Computing LE1600 Button Assembly Replacement: 3 단계, 이미지 3개 중 2개 Motion Computing LE1600 Button Assembly Replacement: 3 단계, 이미지 3개 중 3개
      • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
      • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
      댓글 쓰기
    1. Motion Computing LE1600 Button Assembly Replacement, Button Assembly: 4 단계, 이미지 1개 중 1개
      • Unscrew hard drive panel using a Phillips head #1 screwdriver.
      • (Our device was not given to us with a hard drive or a hard drive panel)
      댓글 쓰기
    2. Motion Computing LE1600 Button Assembly Replacement: 5 단계, 이미지 3개 중 1개 Motion Computing LE1600 Button Assembly Replacement: 5 단계, 이미지 3개 중 2개 Motion Computing LE1600 Button Assembly Replacement: 5 단계, 이미지 3개 중 3개
      • Pull clear plastic tab to detach hard drive from tablet.
      댓글 쓰기
    3. Motion Computing LE1600 Button Assembly Replacement: 6 단계, 이미지 2개 중 1개 Motion Computing LE1600 Button Assembly Replacement: 6 단계, 이미지 2개 중 2개
      • To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
      댓글 쓰기
    4. Motion Computing LE1600 Button Assembly Replacement: 7 단계, 이미지 1개 중 1개
      • Pull the brown tabs to disconnect the white ribbon cable on the other side.
      댓글 쓰기
    5. Motion Computing LE1600 Button Assembly Replacement: 8 단계, 이미지 2개 중 1개 Motion Computing LE1600 Button Assembly Replacement: 8 단계, 이미지 2개 중 2개
      • Caution: do not pull on the wires, instead pull from the plastic connectors.
      • To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
      댓글 쓰기
    6. Motion Computing LE1600 Button Assembly Replacement: 9 단계, 이미지 1개 중 1개
      • With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
      댓글 쓰기
    7. Motion Computing LE1600 Button Assembly Replacement: 10 단계, 이미지 2개 중 1개 Motion Computing LE1600 Button Assembly Replacement: 10 단계, 이미지 2개 중 2개
      • Using a spudger, press in the five tabs on the side where the battery was.
      • This should separate the two halves of the device. Carefully set the side with the motherboard off to the side.
      댓글 쓰기
    8. Motion Computing LE1600 Button Assembly Replacement: 11 단계, 이미지 2개 중 1개 Motion Computing LE1600 Button Assembly Replacement: 11 단계, 이미지 2개 중 2개
      • Unplug the three ribbon cables by pulling on the brown tabs and unplugging cable.
      댓글 쓰기
    9. Motion Computing LE1600 Button Assembly Replacement: 12 단계, 이미지 2개 중 1개 Motion Computing LE1600 Button Assembly Replacement: 12 단계, 이미지 2개 중 2개
      • With a Phillips #1 screwdriver, unscrew the three 4mm screws holding the display bracket on the back side of the front buttons.
      댓글 쓰기
    10. Motion Computing LE1600 Button Assembly Replacement: 13 단계, 이미지 2개 중 1개 Motion Computing LE1600 Button Assembly Replacement: 13 단계, 이미지 2개 중 2개
      • Remove the button board and replace.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Fred Wilby
회원 가입일: 04/03/12
71 평판
안내서 1개를 작성함
Cal Poly, Team 15-14, Forte Spring 2012 Cal Poly, Team 15-14, Forte Spring 2012 회원
CPSU-FORTE-S12S15G14
5 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 65
전체 시간: 2,412
