주요 콘텐츠로 건너뛰기
Moto C Motherboard Assembly Replacement
필요한 것
  1. Moto C Motherboard Assembly Replacement, Back Cover: 1 단계, 이미지 1/3 Moto C Motherboard Assembly Replacement, Back Cover: 1 단계, 이미지 2/3 Moto C Motherboard Assembly Replacement, Back Cover: 1 단계, 이미지 3/3
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or spudger, into the notch on the bottom right corner to start separating the phone unit from the back cover.
    • Move it to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
  2. Moto C Motherboard Assembly Replacement: 2 단계, 이미지 1/2 Moto C Motherboard Assembly Replacement: 2 단계, 이미지 2/2
    • Lift the phone out of the back cover.
  3. Moto C Motherboard Assembly Replacement, Battery: 3 단계, 이미지 1/3 Moto C Motherboard Assembly Replacement, Battery: 3 단계, 이미지 2/3 Moto C Motherboard Assembly Replacement, Battery: 3 단계, 이미지 3/3
    • Use a finger or spudger to lever the battery out of its recess and remove it.
  4. Moto C Motherboard Assembly Replacement, Motherboard Cover: 4 단계, 이미지 1/1
    • Remove the six 3.5 mm long Torx T5 screws.
  5. Moto C Motherboard Assembly Replacement: 5 단계, 이미지 1/2 Moto C Motherboard Assembly Replacement: 5 단계, 이미지 2/2
    • Insert an opening pick between the cover and the motherboard near the SIM 2 slot where the power buttons are located.
    • Slide and twist the opening pick to pry open the plastic clips securing the cover.
  6. Moto C Motherboard Assembly Replacement: 6 단계, 이미지 1/2 Moto C Motherboard Assembly Replacement: 6 단계, 이미지 2/2
    • Slide an opening pick between the cover and the motherboard on the opposite side next to the SD card slot.
    • Twist the opening pick to pry open the plastic clips securing the cover.
  7. Moto C Motherboard Assembly Replacement: 7 단계, 이미지 1/2 Moto C Motherboard Assembly Replacement: 7 단계, 이미지 2/2
    • Remove the motherboard cover.
  8. Moto C Motherboard Assembly Replacement, Motherboard Assembly: 8 단계, 이미지 1/1
    • Remove the three 2.5 mm long T5 Torx screws.
  9. Moto C Motherboard Assembly Replacement: 9 단계, 이미지 1/2 Moto C Motherboard Assembly Replacement: 9 단계, 이미지 2/2
    • Use the tip of an opening pick to pry up and open the black lever of the ZIF connector located on the bottom left of the motherboard.
  10. Moto C Motherboard Assembly Replacement: 10 단계, 이미지 1/2 Moto C Motherboard Assembly Replacement: 10 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
    • Fold the power and volume button flex cable out of the way.
  11. Moto C Motherboard Assembly Replacement: 11 단계, 이미지 1/2 Moto C Motherboard Assembly Replacement: 11 단계, 이미지 2/2
    • Use the flat end of a spudger to pry up and disconnect the display flex cable located at the bottom of the motherboard.
  12. Moto C Motherboard Assembly Replacement: 12 단계, 이미지 1/2 Moto C Motherboard Assembly Replacement: 12 단계, 이미지 2/2
    • Use the tip of an opening pick to pry up and open the black lever of the ZIF connector located at the top of the motherboard next to the rear camera.
  13. Moto C Motherboard Assembly Replacement: 13 단계, 이미지 1/2 Moto C Motherboard Assembly Replacement: 13 단계, 이미지 2/2
    • Use a pair of tweezers to pull the digitizer flex cable out of the ZIF connector.
  14. Moto C Motherboard Assembly Replacement: 14 단계, 이미지 1/1
    • Prepare an iOpener and apply it to the upper half of the display for at least two minutes to loosen the adhesive beneath the vibration motor and the rear facing camera.
  15. Moto C Motherboard Assembly Replacement: 15 단계, 이미지 1/2 Moto C Motherboard Assembly Replacement: 15 단계, 이미지 2/2
    • Don't try to remove the motherboard all the way yet. The antenna cable is still connected to its rear side.
    • Use a spudger to carefully lift the motherboard until you can get a good grip. Avoid to damage the cables next to the motherboard.
  16. Moto C Motherboard Assembly Replacement: 16 단계, 이미지 1/3 Moto C Motherboard Assembly Replacement: 16 단계, 이미지 2/3 Moto C Motherboard Assembly Replacement: 16 단계, 이미지 3/3
    • Fold the motherboard over the battery cavity to access the coaxial cable connectors.
  17. Moto C Motherboard Assembly Replacement: 17 단계, 이미지 1/2 Moto C Motherboard Assembly Replacement: 17 단계, 이미지 2/2
    • Use a pair of tweezers to pry up and disconnect the antenna cable from the back of the motherboard.
  18. Moto C Motherboard Assembly Replacement: 18 단계, 이미지 1/1
    • Remove the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
209,996 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 22
전체 시간: 1,807
