주요 콘텐츠로 건너뛰기
Moto C Plus Battery Replacement
필요한 것
  1. Moto C Plus Battery Replacement, Back Cover: 1 단계, 이미지 1/3 Moto C Plus Battery Replacement, Back Cover: 1 단계, 이미지 2/3 Moto C Plus Battery Replacement, Back Cover: 1 단계, 이미지 3/3
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or spudger, into the notch on the bottom right to start separating the phone unit from the back cover.
    • Move to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
  2. Moto C Plus Battery Replacement: 2 단계, 이미지 1/2 Moto C Plus Battery Replacement: 2 단계, 이미지 2/2
    • Lift the phone out of the back cover.
  3. Moto C Plus Battery Replacement, Battery: 3 단계, 이미지 1/3 Moto C Plus Battery Replacement, Battery: 3 단계, 이미지 2/3 Moto C Plus Battery Replacement, Battery: 3 단계, 이미지 3/3
    • Use a spudger or fingernail to lift the battery starting at the notch on the bottom left.
    • Lever the battery out of its recess and remove it.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
다른 한 분이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
204,077 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,199개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 15
30일 전: 25
전체 시간: 1,483
