주요 콘텐츠로 건너뛰기
Moto C Plus Motherboard Assembly Replacement
필요한 것
  1. Moto C Plus Motherboard Assembly Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Moto C Plus Motherboard Assembly Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Moto C Plus Motherboard Assembly Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or spudger, into the notch on the bottom right to start separating the phone unit from the back cover.
    • Move to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
  2. Moto C Plus Motherboard Assembly Replacement: 2 단계, 이미지 2개 중 1개 Moto C Plus Motherboard Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the phone out of the back cover.
  3. Moto C Plus Motherboard Assembly Replacement, Battery: 3 단계, 이미지 3개 중 1개 Moto C Plus Motherboard Assembly Replacement, Battery: 3 단계, 이미지 3개 중 2개 Moto C Plus Motherboard Assembly Replacement, Battery: 3 단계, 이미지 3개 중 3개
    • Use a spudger or fingernail to lift the battery starting at the notch on the bottom left.
    • Lever the battery out of its recess and remove it.
  4. Moto C Plus Motherboard Assembly Replacement, Motherboard Cover: 4 단계, 이미지 1개 중 1개
    • Remove the five 3.1 mm long Phillips #00 screws.
  5. Moto C Plus Motherboard Assembly Replacement: 5 단계, 이미지 3개 중 1개 Moto C Plus Motherboard Assembly Replacement: 5 단계, 이미지 3개 중 2개 Moto C Plus Motherboard Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Apply an opening pick to the bottom right corner of the motherboard cover.
    • Twist the opening pick to free the motherboard cover out of the plastic clamps on the right side of the phone.
  6. Moto C Plus Motherboard Assembly Replacement: 6 단계, 이미지 2개 중 1개 Moto C Plus Motherboard Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Repeat the previous step on the left side of the motherboard cover to free it out of the plastic clamps.
    • Pry up the motherboard cover until you can get a good grip.
    • Remove the motherboard cover.
  7. Moto C Plus Motherboard Assembly Replacement, Motherboard Assembly: 7 단계, 이미지 1개 중 1개
    • Remove the two 3.2 mm Phillips #00 screws securing the motherboard.
  8. Moto C Plus Motherboard Assembly Replacement: 8 단계, 이미지 2개 중 1개 Moto C Plus Motherboard Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to lift the latch on the power and volume button ZIF connector.
  9. Moto C Plus Motherboard Assembly Replacement: 9 단계, 이미지 2개 중 1개 Moto C Plus Motherboard Assembly Replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
    • Fold the power and volume button flex cable out of the way.
  10. Moto C Plus Motherboard Assembly Replacement: 10 단계, 이미지 2개 중 1개 Moto C Plus Motherboard Assembly Replacement: 10 단계, 이미지 2개 중 2개
    • Pry up and disconnect the antenna cable.
    • Fold the antenna cable out of the way.
  11. Moto C Plus Motherboard Assembly Replacement: 11 단계, 이미지 2개 중 1개 Moto C Plus Motherboard Assembly Replacement: 11 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to open the interconnect cable ZIF connector by lifting the brown flap.
    • When reassembling make sure the white line on the cable aligns with the closed flap.
  12. Moto C Plus Motherboard Assembly Replacement: 12 단계, 이미지 2개 중 1개 Moto C Plus Motherboard Assembly Replacement: 12 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to pull the interconnect flex cable out of the ZIF connector.
  13. Moto C Plus Motherboard Assembly Replacement: 13 단계, 이미지 2개 중 1개 Moto C Plus Motherboard Assembly Replacement: 13 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to open the flap of the ZIF connector next to the headphone jack.
  14. Moto C Plus Motherboard Assembly Replacement: 14 단계, 이미지 2개 중 1개 Moto C Plus Motherboard Assembly Replacement: 14 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to pull the flex cable out of the ZIF connector.
  15. Moto C Plus Motherboard Assembly Replacement: 15 단계, 이미지 2개 중 1개 Moto C Plus Motherboard Assembly Replacement: 15 단계, 이미지 2개 중 2개
    • Don't try to remove the motherboard all the way yet. The display flex cable is still connected to its rear side.
    • Use a spudger to carefully lift the motherboard until you can get a good grip. Avoid to damage the cables next to the motherboard.
    • Lift the motherboard and fold it back until you have enough space to disconnect the display flex cable.
  16. Moto C Plus Motherboard Assembly Replacement: 16 단계, 이미지 2개 중 1개 Moto C Plus Motherboard Assembly Replacement: 16 단계, 이미지 2개 중 2개
    • Use the edge of a spudger to pry up and disconnect the display flex cable from the motherboard.
  17. Moto C Plus Motherboard Assembly Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the motherboard.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
247,693 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
1가이드 댓글
roderyjose9@gmail como hago para encender este mismo teléfono sin el botón de encendido
Rodery Josè Garcia Hidalgo - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 30
전체 시간: 6,926
