주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Moto X Pure Edition Front Camera Replacement
필요한 것
  1. Moto X Pure Edition Front Camera Replacement, Opening Procedure: 1 단계, 이미지 1개 중 1개
    • Prepare an iOpener and heat the back of the phone along its right edge for about five minutes. This will help soften the adhesive securing the back cover.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the LCD display and internal battery are both susceptible to heat damage.
    댓글 쓰기
  2. Moto X Pure Edition Front Camera Replacement: 2 단계, 이미지 3개 중 1개 Moto X Pure Edition Front Camera Replacement: 2 단계, 이미지 3개 중 2개 Moto X Pure Edition Front Camera Replacement: 2 단계, 이미지 3개 중 3개
    • In the following steps, you'll be cutting through the adhesive securing the back cover.
    • The adhesive is laid out as seen in the first image, which shows the inside of the cover.
    • Avoid slicing in this area to avoid damaging delicate ribbon cables.
    댓글 쓰기
  3. Moto X Pure Edition Front Camera Replacement: 3 단계, 이미지 3개 중 1개 Moto X Pure Edition Front Camera Replacement: 3 단계, 이미지 3개 중 2개 Moto X Pure Edition Front Camera Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Hold a pair of pointed tweezers closed, and insert them into the small hole on the edge of the back cover near the SIM card slot.
    • Use the tweezers to lift the cover up slightly, and slide an opening pick into the gap between the cover and the frame.
    댓글 쓰기
  4. Moto X Pure Edition Front Camera Replacement: 4 단계, 이미지 3개 중 1개 Moto X Pure Edition Front Camera Replacement: 4 단계, 이미지 3개 중 2개 Moto X Pure Edition Front Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Slide the opening pick along the edge of the phone to slice through the back cover adhesive.
    • Try to insert the pick as far as you can underneath the cover, toward the center of the cover. There's thick adhesive on the middle of the cover that must be separated.
    • Leave the pick in place as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
    댓글 쓰기
  5. Moto X Pure Edition Front Camera Replacement: 5 단계, 이미지 1개 중 1개
    • Prepare an iOpener and heat the back of the phone along its left edge for about five minutes. This will help soften the adhesive securing the rest of the back cover.
    댓글 쓰기
  6. Moto X Pure Edition Front Camera Replacement: 6 단계, 이미지 2개 중 1개 Moto X Pure Edition Front Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Slice through the adhesive along the bottom edge of the phone.
    • Re-heat the back cover as needed to prevent the glue from cooling and hardening.
    댓글 쓰기
  7. Moto X Pure Edition Front Camera Replacement: 7 단계, 이미지 2개 중 1개 Moto X Pure Edition Front Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Slice through the adhesive along the left side of the phone.
    • Stop cutting when you get to the edge of the volume buttons. Cutting past this point may damage the ribbon cables underneath the cover.
    댓글 쓰기
  8. Moto X Pure Edition Front Camera Replacement: 8 단계, 이미지 3개 중 1개 Moto X Pure Edition Front Camera Replacement: 8 단계, 이미지 3개 중 2개 Moto X Pure Edition Front Camera Replacement: 8 단계, 이미지 3개 중 3개
    • Slice through the adhesive along the top edge of the phone, pulling the pick out slightly to guide it around the rear-facing camera.
    댓글 쓰기
  9. Moto X Pure Edition Front Camera Replacement: 9 단계, 이미지 3개 중 1개 Moto X Pure Edition Front Camera Replacement: 9 단계, 이미지 3개 중 2개 Moto X Pure Edition Front Camera Replacement: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $8.95
    • Carefully pry the cover away from the phone.
    • This may take a lot of force if the adhesive in the middle is still attached. As you lift the cover, you may need to use an opening pick to slice through any remaining adhesive.
    • To reinstall the back cover:
    • First use tweezers and a spudger to peel and scrape away any remaining adhesive from both the back cover and the phone's chassis.
    • Then, clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
    • Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. If that's not available, you can use a high-bond double-sided tape, such as Tesa 61395. Before installing the precut adhesive on the back cover, remove the metal insert. Install the adhesive, then replace the insert.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it.
    댓글 쓰기
  10. Moto X Pure Edition Front Camera Replacement: 10 단계, 이미지 3개 중 1개 Moto X Pure Edition Front Camera Replacement: 10 단계, 이미지 3개 중 2개 Moto X Pure Edition Front Camera Replacement: 10 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry up the rubber cover over the battery connector.
    • Remove the rubber cover.
    댓글 쓰기
  11. Moto X Pure Edition Front Camera Replacement: 11 단계, 이미지 2개 중 1개 Moto X Pure Edition Front Camera Replacement: 11 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry the battery connector straight up and out of its socket.
    • Only pry the small tab on the end of the connector opposite the ribbon cable. Do not push against the connector too hard or you risk damaging the plug on the motherboard.
    댓글 쓰기
  12. Moto X Pure Edition Front Camera Replacement: 12 단계, 이미지 2개 중 1개 Moto X Pure Edition Front Camera Replacement: 12 단계, 이미지 2개 중 2개
    • Use tweezers to lift away the rubber cover over the flash connector.
    댓글 쓰기
  13. Moto X Pure Edition Front Camera Replacement: 13 단계, 이미지 2개 중 1개 Moto X Pure Edition Front Camera Replacement: 13 단계, 이미지 2개 중 2개
    • Use the tip of a spudger against the corner of the flash connector to pry the connecter straight up and out of its socket.
    댓글 쓰기
  14. Moto X Pure Edition Front Camera Replacement: 14 단계, 이미지 1개 중 1개
    • Use a T3 Torx driver to remove twenty 2.4 mm screws.
    댓글 쓰기
  15. Moto X Pure Edition Front Camera Replacement: 15 단계, 이미지 2개 중 1개 Moto X Pure Edition Front Camera Replacement: 15 단계, 이미지 2개 중 2개
    • Use the point of a spudger to push the small clip securing the left side of the midframe toward the edge of the phone, releasing the clip.
    댓글 쓰기
  16. Moto X Pure Edition Front Camera Replacement: 16 단계, 이미지 1개 중 1개
    • Repeat the previous step to release the right side midframe clip.
    댓글 쓰기
  17. Moto X Pure Edition Front Camera Replacement: 17 단계, 이미지 3개 중 1개 Moto X Pure Edition Front Camera Replacement: 17 단계, 이미지 3개 중 2개 Moto X Pure Edition Front Camera Replacement: 17 단계, 이미지 3개 중 3개
    • Holding the display by the edges, gently lift the midframe away from the display.
    • Remove the midframe from the display.
    댓글 쓰기
  18. Moto X Pure Edition Front Camera Replacement, Front Camera: 18 단계, 이미지 2개 중 1개 Moto X Pure Edition Front Camera Replacement, Front Camera: 18 단계, 이미지 2개 중 2개
    • Use the flat end of the nylon spudger to gently pry up on the front camera connector.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Robert Petitpas
회원 가입일: 03/04/16
275 평판
안내서 1개를 작성함
UMass Dartmouth, Team 5-2, Landers Spring 2016 UMass Dartmouth, Team 5-2, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G2
3 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 26
전체 시간: 1,652
