주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Moto Z Rear-Facing Camera Replacement
필요한 것
  1. Moto Z Rear-Facing Camera Replacement, Display Assembly: 1 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the left edge of the phone for at least 90 seconds.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
    • As you're waiting for the adhesive to soften, move on and read the following step to get an idea of where to pry.
    댓글 쓰기
  2. Moto Z Rear-Facing Camera Replacement: 2 단계, 이미지 2개 중 1개 Moto Z Rear-Facing Camera Replacement: 2 단계, 이미지 2개 중 2개
    • In the following steps you will be cutting through the adhesive around the edge of the display assembly.
    • To avoid damage, do not cut in the following areas:
    • The OLED panel
    • The home button
    • The flash unit
    댓글 쓰기
  3. Moto Z Rear-Facing Camera Replacement: 3 단계, 이미지 3개 중 1개 Moto Z Rear-Facing Camera Replacement: 3 단계, 이미지 3개 중 2개 Moto Z Rear-Facing Camera Replacement: 3 단계, 이미지 3개 중 3개
    • Apply a suction cup as close to the heated edge as possible.
    • Lift on the suction cup and insert the tip of an opening pick into the gap.
    • Do not insert the pick more than 1/16" (1.5 mm). Over-inserting the pick may damage the OLED panel.
    댓글 쓰기
  4. Moto Z Rear-Facing Camera Replacement: 4 단계, 이미지 3개 중 1개 Moto Z Rear-Facing Camera Replacement: 4 단계, 이미지 3개 중 2개 Moto Z Rear-Facing Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully slide the tip of the opening pick down and up the side of the phone, making sure not to cut deeper than 1/16" (1.5 mm).
    • As you run the pick along the side, you will feel the tip of the pick press against the edge of the OLED panel. That is as far as the pick should go without damaging the panel.
    • Once you have separated the adhesive, leave an opening pick in the side to keep the adhesive from resealing.
    댓글 쓰기
  5. Moto Z Rear-Facing Camera Replacement: 5 단계, 이미지 1개 중 1개
    • Repeat the heating, lifting, and cutting steps for the remaining long edge of the phone.
    댓글 쓰기
  6. Moto Z Rear-Facing Camera Replacement: 6 단계, 이미지 1개 중 1개
    댓글 쓰기
  7. Moto Z Rear-Facing Camera Replacement: 7 단계, 이미지 2개 중 1개 Moto Z Rear-Facing Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Insert an opening pick into the flash side corner of the phone and carefully slice around the flash unit.
    • Do not insert the pick more than 1/16" (1.5 mm) into the edge.
    • Once you are done cutting, leave the pick in the corner to prevent the adhesive from resealing.
    댓글 쓰기
  8. Moto Z Rear-Facing Camera Replacement: 8 단계, 이미지 3개 중 1개 Moto Z Rear-Facing Camera Replacement: 8 단계, 이미지 3개 중 2개 Moto Z Rear-Facing Camera Replacement: 8 단계, 이미지 3개 중 3개
    • Insert an opening pick into the remaining top corner of the phone.
    • Carefully slice through the adhesive across the top of the phone.
    • Do not insert the pick beyond 1/2" (12.5 mm).
    댓글 쓰기
  9. Moto Z Rear-Facing Camera Replacement: 9 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the bottom edge of the phone for at least 90 seconds.
    댓글 쓰기
  10. Moto Z Rear-Facing Camera Replacement: 10 단계, 이미지 3개 중 1개 Moto Z Rear-Facing Camera Replacement: 10 단계, 이미지 3개 중 2개 Moto Z Rear-Facing Camera Replacement: 10 단계, 이미지 3개 중 3개
    • Insert an opening pick into a bottom corner and slice towards the home button, stopping before you reach it.
    • Once you're done with the corner, leave a pick in place to prevent the adhesive from sealing.
    • Repeat the process for the other bottom corner.
    댓글 쓰기
  11. Moto Z Rear-Facing Camera Replacement: 11 단계, 이미지 2개 중 1개 Moto Z Rear-Facing Camera Replacement: 11 단계, 이미지 2개 중 2개
    • Carefully twist the first opening pick slightly to help release the edge adhesive.
    • Repeat the same process for each remaining pick, moving them as necessary and twisting slightly to release the adhesive.
    댓글 쓰기
  12. Moto Z Rear-Facing Camera Replacement: 12 단계, 이미지 3개 중 1개 Moto Z Rear-Facing Camera Replacement: 12 단계, 이미지 3개 중 2개 Moto Z Rear-Facing Camera Replacement: 12 단계, 이미지 3개 중 3개
    • Lift the earpiece end of the display up to provide access to the display cables.
    • Do not open the display beyond 90 degrees, and always support the display panel.
    댓글 쓰기
  13. Moto Z Rear-Facing Camera Replacement: 13 단계, 이미지 3개 중 1개 Moto Z Rear-Facing Camera Replacement: 13 단계, 이미지 3개 중 2개 Moto Z Rear-Facing Camera Replacement: 13 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry the display cable shield up.
    • Remove the display cable shield.
    댓글 쓰기
  14. Moto Z Rear-Facing Camera Replacement: 14 단계, 이미지 2개 중 1개 Moto Z Rear-Facing Camera Replacement: 14 단계, 이미지 2개 중 2개
    • Use the point of the spudger to lift and disconnect the display cable connector from its socket.
    댓글 쓰기
  15. Moto Z Rear-Facing Camera Replacement: 15 단계, 이미지 2개 중 1개 Moto Z Rear-Facing Camera Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the display assembly.
    • Compare your new replacement part to the original part. You may need to transfer remaining components (such as the flash lens) or remove adhesive backings from the new part before installing.
    • Before you reinstall the display assembly, thoroughly remove any remaining adhesive and glass from the frame.
    • After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Use the Motorola Moto Z display adhesive to reseal your phone. Follow this guide for instructions on how to apply adhesive to the replacement screen.
    댓글 쓰기
  16. Moto Z Rear-Facing Camera Replacement, Rear-Facing Camera: 16 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Place the tweezers under the copper tab on the top of the device.
    • Make sure you have a firm grip on the tab with the tweezers.
    • Make sure not to puncture the battery with the metal tweezers as it's a fire hazard.
    댓글 쓰기
  17. Moto Z Rear-Facing Camera Replacement: 17 단계, 이미지 1개 중 1개
    • Slowly and carefully lift up on the tab until it pops out of the phone and is only connected by the black tape.
    댓글 쓰기
  18. Moto Z Rear-Facing Camera Replacement: 18 단계, 이미지 2개 중 1개 Moto Z Rear-Facing Camera Replacement: 18 단계, 이미지 2개 중 2개
    • Using the tweezers, firmly grab the black connecting tape closest to the lens.
    • Gently pull to the right until the camera (lens and black tape) disconnects from the device.
    댓글 쓰기
결론
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our [|Motorola Moto Z Answers community] for troubleshooting help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Miriam Lam
회원 가입일: 01/24/18
1,188 평판
안내서 5개를 작성함
Cal Poly, Team S2-G2, Livingston Winter 2018 Cal Poly, Team S2-G2, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S2G2
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 51
전체 시간: 1,305
