주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Atrix HD Battery Replacement
필요한 것
  1. Motorola Atrix HD Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Motorola Atrix HD Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Motorola Atrix HD Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before disassembling the phone, remove the SIM card and the MICRO-SD card, if equipped.
    • Begin taking apart the device by prying apart the back cover from the assembly using the plastic opening tool.
    • Continue working around the edge of the phone using the plastic opening tool.
    • When all the edges have been lifted apart, use your hands or plastic opening tool to peel the back plate from the battery. There are small adhesive strips between the back cover and the battery, so take care not to crack the back cover while prying open.
    댓글 쓰기
  2. Motorola Atrix HD Battery Replacement: 2 단계, 이미지 1개 중 1개
    • The adhesive strips are shown in the orange boxes. Be sure not to use too much force to pull off the back cover, or you may risk snapping the back cover.
    댓글 쓰기
  3. Motorola Atrix HD Battery Replacement: 3 단계, 이미지 3개 중 1개 Motorola Atrix HD Battery Replacement: 3 단계, 이미지 3개 중 2개 Motorola Atrix HD Battery Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the red rubber screw cover with a pair of tweezers
    댓글 쓰기
  4. Motorola Atrix HD Battery Replacement: 4 단계, 이미지 2개 중 1개 Motorola Atrix HD Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Use the T-5 Torx bit to remove the two silver 3.3 mm screws with integrated washers.
    댓글 쓰기
  5. Motorola Atrix HD Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the battery leads to the upward position. The ribbon cable is very thin, be gentle.
    댓글 쓰기
  6. Motorola Atrix HD Battery Replacement: 6 단계, 이미지 3개 중 1개 Motorola Atrix HD Battery Replacement: 6 단계, 이미지 3개 중 2개 Motorola Atrix HD Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Use the plastic opening tool around the edges to loosen the battery.
    • Once the battery is loose, carefully lift from the bottom edge and remove the battery.
    댓글 쓰기
  7. Motorola Atrix HD Battery Replacement: 7 단계, 이미지 1개 중 1개
    • The battery may now be removed.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Bradley Hinckley
회원 가입일: 10/28/15
561 평판
안내서 2개를 작성함
UMass Dartmouth, Team 1-8, Miles Fall 2015 UMass Dartmouth, Team 1-8, Miles Fall 2015 회원
UMASSD-MILES-F15S1G8
3 회원들
안내서 15개를 작성함
1가이드 댓글
How do you calibrate it then? Lights up green dot, charges, won't work! Multi tester shows full power.
jvandeputte - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 44
전체 시간: 3,706
