주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Defy XT Camera Replacement
필요한 것
    1. Motorola Defy XT Camera Replacement, Camera: 1 단계, 이미지 1개 중 1개
      • Locate the opening on the corner of the Motorola Defy XT mobile phone.
      • Wedge the Plastic Opening Tool between the back cover and the body of the phone.
      댓글 쓰기
    2. Motorola Defy XT Camera Replacement: 2 단계, 이미지 1개 중 1개
      • Once wedged in the opening, gently pry around the phone until back cover lifts off.
      댓글 쓰기
    3. Motorola Defy XT Camera Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the back cover and locate the battery.
      • Insert the opening tool beneath the battery and lightly push upward.
      댓글 쓰기
    4. Motorola Defy XT Camera Replacement: 4 단계, 이미지 1개 중 1개
      • Locate the SD card beneath the plastic cover in the corner.
      • Use a Plastic Opening Tool to hook the edge of the SD card
      댓글 쓰기
    5. Motorola Defy XT Camera Replacement: 5 단계, 이미지 1개 중 1개
      • Push the SD card straight out.
      댓글 쓰기
    6. Motorola Defy XT Camera Replacement: 6 단계, 이미지 1개 중 1개
      • Use the T4 Torque Driver to remove all 6 of the 3mm diameter screws on the outside edges of the phone.
      댓글 쓰기
    7. Motorola Defy XT Camera Replacement: 7 단계, 이미지 1개 중 1개
      • Wedge the Plastic Opening Tool under the inner side of the volume buttons.
      • Pop the volume buttons out of the phone.
      댓글 쓰기
    8. Motorola Defy XT Camera Replacement: 8 단계, 이미지 1개 중 1개
      • Locate the base of the motherboard.
      • Slide the Plastic Opening Tool along the base of the motherboard to separate it from the phone.
      • Gently guide the two pieces apart with upward motion.
      • Caution: Do not damage the ribbon that is holding both pieces
      댓글 쓰기
    9. Motorola Defy XT Camera Replacement: 9 단계, 이미지 1개 중 1개
      • Disconnect the ribbon from the frame.
      • Remove the screen.
      댓글 쓰기
    10. Motorola Defy XT Camera Replacement: 10 단계, 이미지 1개 중 1개
      • Flip the mother board over.
      • Locate the base of the ribbon cable.
      • Pull straight outward using the Plastic Opening Tool.
      • Disconnect the ribbon cable connecting the display to the logic board
      댓글 쓰기
    11. Motorola Defy XT Camera Replacement: 11 단계, 이미지 1개 중 1개
      • Pull the two halves of the device apart to disconnect the second (wider) ribbon connector.
      • Note: The ribbon connector is bonded to the logic board with adhesive, simply pull it to remove it completely.
      댓글 쓰기
    12. Motorola Defy XT Camera Replacement: 12 단계, 이미지 1개 중 1개
      • Use the Plastic Opening Tool to disconnect the camera from the logic board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Mustapha Nadri
회원 가입일: 04/19/13
1 평판
안내서 1개를 작성함
Cal Poly, Team 2-22, Maness Spring 2013 Cal Poly, Team 2-22, Maness Spring 2013 회원
CPSU-MANESS-S13S2G22
3 회원들
안내서 48개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 27
전체 시간: 1,223
