주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Defy XT Logic Board Replacement
필요한 것
    1. Motorola Defy XT Logic Board Replacement, Logic Board: 1 단계, 이미지 1개 중 1개
      • Wedge the opening tool in-between the back cover and the body of the phone in the opening denoted by the arrow.
      댓글 쓰기
    2. Motorola Defy XT Logic Board Replacement: 2 단계, 이미지 1개 중 1개
      • Once wedged in the opening, slide the opening tool around the side of the phone and remove the back cover, setting it aside.
      댓글 쓰기
    3. Motorola Defy XT Logic Board Replacement: 3 단계, 이미지 1개 중 1개
      • Insert the opening tool between the battery and the battery holder and wedge the battery out.
      댓글 쓰기
    4. Motorola Defy XT Logic Board Replacement: 4 단계, 이미지 1개 중 1개
      • Open the plastic cover with your finger to expose the SD card.
      • Use the opening tool to grab the edge of the SD card and pull it straight out.
      댓글 쓰기
    5. Motorola Defy XT Logic Board Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the six 6mm T4 screws with the T4 torque driver.
      댓글 쓰기
    6. Motorola Defy XT Logic Board Replacement: 6 단계, 이미지 1개 중 1개
      • Pop out the volume button with the plastic opening tool.
      댓글 쓰기
    7. Motorola Defy XT Logic Board Replacement: 7 단계, 이미지 2개 중 1개 Motorola Defy XT Logic Board Replacement: 7 단계, 이미지 2개 중 2개
      • Wedge the plastic opening tool in-between the plastic layer and the front cover.
      • Do not completely separate the two pieces to avoid damaging the ribbon cable inside.
      댓글 쓰기
    8. Motorola Defy XT Logic Board Replacement: 8 단계, 이미지 1개 중 1개
      • Carefully separate the bottom piece from the top plastic piece.
      • Disconnect the ribbon cable connecting the display to the logic board by firmly pulling the cable straight outward.
      • The screen can now be removed.
      댓글 쓰기
    9. Motorola Defy XT Logic Board Replacement: 9 단계, 이미지 1개 중 1개
      • Separate the logic board and the display cover from the back cover and orient the logic board so the camera faces toward you.
      • Disconnect the back cover by wedging the plastic opening tool in between the motherboard and the connector and prying outward.
      댓글 쓰기
    10. Motorola Defy XT Logic Board Replacement: 10 단계, 이미지 1개 중 1개
      • Flip the logic board and display cover over so the camera faces away from you.
      • Bend the two halves of the device away from you to pry the final ribbon connector off the logic board.
      • The ribbon connector is bonded to the logic board with adhesive, simply pull it to break the glue bond.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
No Name
회원 가입일: 04/21/13
25 평판
안내서 1개를 작성함
2가이드 댓글
Imbecells give up DEMONIC HOLD PRAISE THE LORD HE HAS COME 4 U
True Seminary - 답글 공유
idoits have faith like a lil ole mustard seed
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 41
전체 시간: 1,727
