주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Defy XT SD Card Replacement
필요한 것
  1. Motorola Defy XT SD Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
    댓글 쓰기
  2. Motorola Defy XT SD Card Replacement: 2 단계, 이미지 1개 중 1개
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
    댓글 쓰기
  3. Motorola Defy XT SD Card Replacement: 3 단계, 이미지 1개 중 1개
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
    댓글 쓰기
  4. Motorola Defy XT SD Card Replacement, SD Card: 4 단계, 이미지 1개 중 1개
    • Open the plastic cover with your finger, exposing the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Dorian Capps
회원 가입일: 04/19/13
64 평판
안내서 2개를 작성함
Cal Poly, Team 2-22, Maness Spring 2013 Cal Poly, Team 2-22, Maness Spring 2013 회원
CPSU-MANESS-S13S2G22
3 회원들
안내서 16개를 작성함
2가이드 댓글
I have replaced the SD card --32 GB---with smaller GB card-- and still my XT phone does not allow movement of APP to this card or saving photo files.
Any other suggestions to get phone to recognize the new card. Cant drag an APP (calculator, eg) to that memory card.
Must I format or seat the card ? or get a different brand ScanDisk 32?
Memorex 8 with Settings reads 7.2 GB total space on this smaller new card.
Gardner
Gardner Neely - 답글 공유
thanks for any guidance on memory card problems Mounting/activating so that I can add files or APPS to that SD card on my Motorola Defy XT 2012 mobile phone.
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 21
전체 시간: 2,632
