주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Defy XT Screen Replacement
필요한 것
  1. Motorola Defy XT Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
    댓글 쓰기
  2. Motorola Defy XT Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
    댓글 쓰기
  3. Motorola Defy XT Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
    댓글 쓰기
  4. Motorola Defy XT Screen Replacement, SD Card: 4 단계, 이미지 1개 중 1개
    • Open the plastic cover with your finger, exposing the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
    댓글 쓰기
  5. Motorola Defy XT Screen Replacement, Screen: 5 단계, 이미지 2개 중 1개 Motorola Defy XT Screen Replacement, Screen: 5 단계, 이미지 2개 중 2개
    • Use the Torx T4 screwdriver to remove the six 3 mm screws from the back case.
    댓글 쓰기
  6. Motorola Defy XT Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to pop the volume buttons off from the side of the phone.
    댓글 쓰기
  7. Motorola Defy XT Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Wedge the plastic opening tool between the plastic layer and the shiny front cover.
    댓글 쓰기
  8. Motorola Defy XT Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Slide the plastic opening tool along the edge, wedging the the two pieces apart.
    • Potential for device damage: Do not completely separate the two pieces; there are still internal components that need to be disconnected.
    댓글 쓰기
  9. Motorola Defy XT Screen Replacement: 9 단계, 이미지 2개 중 1개 Motorola Defy XT Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Slide the screen out and disconnect the ribbon cable connecting the display to the motherboard by pulling straight outward.
    • Potential for device damage: Be careful when sliding out the screen because the front case and the motherboard are still connected by two other ribbon cables.
    댓글 쓰기
  10. Motorola Defy XT Screen Replacement: 10 단계, 이미지 2개 중 1개 Motorola Defy XT Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Set the old screen aside and replace it with your new screen.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Oscar Camacho
회원 가입일: 04/19/13
89 평판
안내서 1개를 작성함
Cal Poly, Team 2-22, Maness Spring 2013 Cal Poly, Team 2-22, Maness Spring 2013 회원
CPSU-MANESS-S13S2G22
3 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 42
전체 시간: 3,644
