주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Droid 4 MicroSD/SIM Card Reader Replacement
필요한 것
  1. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Removing Rear Panel: 1 단계, 이미지 3개 중 1개 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Removing Rear Panel: 1 단계, 이미지 3개 중 2개 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Removing Rear Panel: 1 단계, 이미지 3개 중 3개
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
    댓글 쓰기
  2. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Remove the sticker on the rear compartment to reveal the battery.
    • Hold the battery with your thumb while removing the sticker or you might end up ripping the battery out of the phone, damaging the flex cable.
    댓글 쓰기
  3. Motorola Droid 4 MicroSD/SIM Card Reader Replacement: 3 단계, 이미지 2개 중 1개 Motorola Droid 4 MicroSD/SIM Card Reader Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    T5 Torx Screwdriver
    $5.49
    • Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
    • Use the Spudger to unstick the battery.
    • It's difficult to remove the battery without a pry tool like the spudger because of the strong adhesive. If you try removing it with just your fingers, the battery may bend.
    댓글 쓰기
  4. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Camera Cover Removal: 4 단계, 이미지 3개 중 1개 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Camera Cover Removal: 4 단계, 이미지 3개 중 2개 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Camera Cover Removal: 4 단계, 이미지 3개 중 3개
    • Using the blue plastic opening tool, pry off the thin plastic camera cover.
    • The plastic cover is fragile, so proceed carefully.
    댓글 쓰기
  5. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Remove Screws: 5 단계, 이미지 2개 중 1개 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Remove Screws: 5 단계, 이미지 2개 중 2개
    • Remove the four screws, indicated by the red circles, with the screwdriver and T5 Torx bit.
    • The screws are philips 2.5mm. One screw is a different color (silver) from the others (black).
    댓글 쓰기
  6. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Remove Bezel: 6 단계, 이미지 3개 중 1개 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Remove Bezel: 6 단계, 이미지 3개 중 2개 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Remove Bezel: 6 단계, 이미지 3개 중 3개
    • Insert the spudger between the rear bezel and the main housing.
    • The bezel is fragile, so proceed carefully.
    • Slide the spudger around all sides of the phone to separate the bezel from the housing.
    • Pry the bezel free.
    • Be careful of the adhesive that holds the bezel to the main housing. Prying too hard may damage your phone.
    댓글 쓰기
  7. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Removing screws: 7 단계, 이미지 2개 중 1개 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Removing screws: 7 단계, 이미지 2개 중 2개
    • Remove the 12 screws holding the housing in place using a T5 Torx screwdriver.
    • Follow the red circles, indicated in the picture, to locate the screws.
    • The 12 screws are (silver) philips 2.5mm
    댓글 쓰기
  8. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separation of the Housing from the Motherboard: 8 단계, 이미지 3개 중 1개 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separation of the Housing from the Motherboard: 8 단계, 이미지 3개 중 2개 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separation of the Housing from the Motherboard: 8 단계, 이미지 3개 중 3개
    • Separate the housing from the motherboard.
    • Be careful while separating the housing. The power and volume buttons are easily separated from the housing and can be damaged.
    댓글 쓰기
  9. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, MicroSD/SIM Card Reader: 9 단계, 이미지 3개 중 1개 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, MicroSD/SIM Card Reader: 9 단계, 이미지 3개 중 2개 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, MicroSD/SIM Card Reader: 9 단계, 이미지 3개 중 3개
    • Once the Motherboard Housing is removed the complete Micro SD/SIM card reader is exposed, as indicated by the picture.
    • Remove the two screws that attach the reader to the Motherboard. The locations of the screws are indicated in the picture.
    댓글 쓰기
  10. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separate the reader from the motherboard: 10 단계, 이미지 3개 중 1개 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separate the reader from the motherboard: 10 단계, 이미지 3개 중 2개 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separate the reader from the motherboard: 10 단계, 이미지 3개 중 3개
    • Using the spudger, pry off the Reader.
    • Be careful while removing the Reader. The connection to the motherboard is composed of small pins.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Javier
회원 가입일: 09/29/14
533 평판
안내서 4개를 작성함
USF Tampa, Team 5-1, Mcgee Fall 2014 USF Tampa, Team 5-1, Mcgee Fall 2014 회원
USFT-MCGEE-F14S5G1
5 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 36
전체 시간: 2,065
