주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Droid Pro Motherboard Replacement
필요한 것
  1. Motorola Droid Pro Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the back cover using the thumb tab located on the bottom of the phone.
    댓글 쓰기
  2. Motorola Droid Pro Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Motorola Droid Pro Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the battery using the thumb tab.
    댓글 쓰기
  3. Motorola Droid Pro Motherboard Replacement, SD Card/SIM Card PCB Board: 3 단계, 이미지 2개 중 1개 Motorola Droid Pro Motherboard Replacement, SD Card/SIM Card PCB Board: 3 단계, 이미지 2개 중 2개
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
    댓글 쓰기
  4. Motorola Droid Pro Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Motorola Droid Pro Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Motorola Droid Pro Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
    댓글 쓰기
  5. Motorola Droid Pro Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Motorola Droid Pro Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
    댓글 쓰기
  6. Motorola Droid Pro Motherboard Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 Motorola Droid Pro Motherboard Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
    • Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
    • There are small tabs on the side of the connectors to wedge your tool under.
    댓글 쓰기
  7. Motorola Droid Pro Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Motorola Droid Pro Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Use your plastic opening tool to disconnect the two ribbon cables at the top of the phone.
    댓글 쓰기
  8. Motorola Droid Pro Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Motorola Droid Pro Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the 2nd keyboard connector from the motherboard and remove it from its side holders.
    • This cable is fragile so be careful when disconnecting and moving it around.
    댓글 쓰기
  9. Motorola Droid Pro Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Use a T5 Torx Screwdriver to unscrew the 2mm screw.
    댓글 쓰기
  10. Motorola Droid Pro Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Motorola Droid Pro Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Motorola Droid Pro Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Remove the camera's rubber seal by pulling it off. It is not connected to anything.
    댓글 쓰기
  11. Motorola Droid Pro Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Motorola Droid Pro Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • To remove the motherboard, pull it to the side. The camera that is connected to the motherboard does not pull straight up and out from its holder.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Richard Bellizzi
회원 가입일: 10/28/15
352 평판
안내서 2개를 작성함
UMass Dartmouth, Team 1-6, Miles Fall 2015 UMass Dartmouth, Team 1-6, Miles Fall 2015 회원
UMASSD-MILES-F15S1G6
3 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 34
전체 시간: 671
