주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Droid RAZR HD Front Panel Replacement
필요한 것
  1. Motorola Droid RAZR HD Front Panel Replacement, Front Panel Assembly: 1 단계, 이미지 1개 중 1개
    • Power off the device before disassembly to avoid damage or harm from electrical surges.
    • Remove the two 4.5mm screws in the bottom left and right corners of the device using a T4 Torx Screwdriver.
    댓글 쓰기
  2. Motorola Droid RAZR HD Front Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Holding the device in your hand, push the screen towards the top of the phone until it disconnects from the base of the phone.
    댓글 쓰기
  3. Motorola Droid RAZR HD Front Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to lift the screen from the phone.
    • Do not try to completely detach the screen; cables are still connected to the device and can be damaged.
    댓글 쓰기
  4. Motorola Droid RAZR HD Front Panel Replacement: 4 단계, 이미지 2개 중 1개 Motorola Droid RAZR HD Front Panel Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to remove the yellow tape covering the lcd/digitizer cable connector.
    • Carefully lift up the black locking tab to release the lcd/digitizer cable.
    • The cable connector is located on the bottom right section of the phone.
    댓글 쓰기
  5. Motorola Droid RAZR HD Front Panel Replacement: 5 단계, 이미지 1개 중 1개
    • Lift up the screen further to reveal another cable at the top of the device connecting the motherboard to the screen.
    • This connector is located on the top right section of the phone.
    • Use tweezers to lift the black bar on top of the ZIF connector.
    • Pull the ribbon cable out of the connector with tweezers.
    • Now that there are no cables connecting the screen to the motherboard, remove the screen.
    댓글 쓰기
  6. Motorola Droid RAZR HD Front Panel Replacement, Front Panel: 6 단계, 이미지 2개 중 1개 Motorola Droid RAZR HD Front Panel Replacement, Front Panel: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the two 2.0mm T4 Torx screws near the top of the screen.
    • Remove the metal plate protecting the front camera and ear speaker with tweezers.
    댓글 쓰기
  7. Motorola Droid RAZR HD Front Panel Replacement: 7 단계, 이미지 2개 중 1개 Motorola Droid RAZR HD Front Panel Replacement: 7 단계, 이미지 2개 중 2개
    • Using a plastic openining tool, lift up the front camera and ear speaker assembly.
    • Remove the assembly with tweezers.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Brendan Baronia
회원 가입일: 04/14/15
681 평판
안내서 2개를 작성함
Cal Poly, Team 4-4, Maness Spring 2015 Cal Poly, Team 4-4, Maness Spring 2015 회원
CPSU-MANESS-S15S4G4
5 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 25
전체 시간: 2,016
