주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Droid RAZR M Display Replacement
필요한 것
  1. Motorola Droid RAZR M Display Replacement, Front Assembly: 1 단계, 이미지 3개 중 1개 Motorola Droid RAZR M Display Replacement, Front Assembly: 1 단계, 이미지 3개 중 2개 Motorola Droid RAZR M Display Replacement, Front Assembly: 1 단계, 이미지 3개 중 3개
    • Open the small latch on the left side of the device by lifting gently with your finger, exposing the SIM card and microSD card slots.
    • If either of these cards are present, remove them to prevent damaging them while taking apart the phone. Our device does not have either.
    • Close the latch once the two cards are removed.
    댓글 쓰기
  2. Motorola Droid RAZR M Display Replacement: 2 단계, 이미지 3개 중 1개 Motorola Droid RAZR M Display Replacement: 2 단계, 이미지 3개 중 2개 Motorola Droid RAZR M Display Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the six 4mm T3 Torx screws. There are 3 on each side of the device.
    댓글 쓰기
  3. Motorola Droid RAZR M Display Replacement: 3 단계, 이미지 3개 중 1개 Motorola Droid RAZR M Display Replacement: 3 단계, 이미지 3개 중 2개 Motorola Droid RAZR M Display Replacement: 3 단계, 이미지 3개 중 3개
    • Run the plastic opening tool under the bottom edge of the phone to detach the small plastic cover below the Verizon logo.
    • It will take some force to remove this piece. Work around the bottom corners to unlatch the two hooks holding the piece in place.
    • The small plastic hooks can break during removal. Be careful that you don't damage them, but it will take some force to get them undone.
    • Once the plastic cover is detached, pull the piece away with your fingers.
    댓글 쓰기
  4. Motorola Droid RAZR M Display Replacement: 4 단계, 이미지 2개 중 1개 Motorola Droid RAZR M Display Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the three T4 Torx screws. There are three at the bottom of the device.
    댓글 쓰기
  5. Motorola Droid RAZR M Display Replacement: 5 단계, 이미지 3개 중 1개 Motorola Droid RAZR M Display Replacement: 5 단계, 이미지 3개 중 2개 Motorola Droid RAZR M Display Replacement: 5 단계, 이미지 3개 중 3개
    • Using the plastic opening tool, peel away the silver Motorola plate at the top of the phone. There is a fair amount of adhesive underneath, so you may have to pry it from a few different angles.
    • As soon as you can get your finger underneath, pull away the silver plate.
    댓글 쓰기
  6. Motorola Droid RAZR M Display Replacement: 6 단계, 이미지 2개 중 1개 Motorola Droid RAZR M Display Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the two 7mm T4 Torx screws at the top of the device.
    댓글 쓰기
  7. Motorola Droid RAZR M Display Replacement: 7 단계, 이미지 3개 중 1개 Motorola Droid RAZR M Display Replacement: 7 단계, 이미지 3개 중 2개 Motorola Droid RAZR M Display Replacement: 7 단계, 이미지 3개 중 3개
    • When you detach the front from the back, don't pull the two pieces entirely apart. There is a flat orange wire that connects the two pieces that will be disconnected in the next step.
    • Snap apart the two internal clips located on the top corners of the device, and the two clips in the bottom corners.
    • Run the plastic opening tool around the edge of the entire device to pry apart the front of the phone from the back.
    • There is a small black plastic piece located at the bottom of the front assembly. Do not worry if the strip falls off; just simply snap it back on and proceed.
    댓글 쓰기
  8. Motorola Droid RAZR M Display Replacement: 8 단계, 이미지 3개 중 1개 Motorola Droid RAZR M Display Replacement: 8 단계, 이미지 3개 중 2개 Motorola Droid RAZR M Display Replacement: 8 단계, 이미지 3개 중 3개
    • Like a clamshell, slowly open the device from the top. Open the remainder of the device slowly while being mindful of the flat orange wire that connects the motherboard to the front assembly.
    • Undo the snap connection in the lower left corner by inserting the plastic opening tool under the end of the orange wire connected to the motherboard. Lift gently.
    • Once the snap connection is undone, pull apart the front assembly from the rest of the phone.
    댓글 쓰기
  9. Motorola Droid RAZR M Display Replacement, Display: 9 단계, 이미지 1개 중 1개
    • Holding the front assembly, carefully peel back the flat orange wire that is attached to the display from the silver backing. The silver backing is the plating where the speaker is located.'''
    댓글 쓰기
  10. Motorola Droid RAZR M Display Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the speaker from the display by unhooking it from the two small metal spines on either side of the speaker marked by two the red squares.
    • In addition to the two metal spines, there is adhesive underneath the top of the silver plating of the speaker attaching it to the display.
    댓글 쓰기
  11. Motorola Droid RAZR M Display Replacement: 11 단계, 이미지 1개 중 1개
    • Carefully lift the silver plating out of the metal spines, separating it from the display.
    • You will then be left with display with the orange wire attached.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Connor HennesseyNiland
회원 가입일: 04/23/15
372 평판
안내서 1개를 작성함
Cal Poly, Team 15-1, Amido Spring 2015 Cal Poly, Team 15-1, Amido Spring 2015 회원
CPSU-AMIDO-S15S15G1
4 회원들
안내서 28개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 33
전체 시간: 3,003
