주요 콘텐츠로 건너뛰기
Motorola Edge (2022) Daughterboard Replacement
필요한 것
  1. Motorola Edge (2022) Daughterboard Replacement, Remove the SIM card tray: 1 단계, 이미지 3개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Remove the SIM card tray: 1 단계, 이미지 3개 중 2개 Motorola Edge (2022) Daughterboard Replacement, Remove the SIM card tray: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Insert a SIM eject tool, bit, or straightened paperclip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the sim card tray hole to eject the SIM card tray.
    • Use your fingers or tweezers to remove the SIM card tray.
  2. Motorola Edge (2022) Daughterboard Replacement, Heat the right edge: 2 단계, 이미지 1개 중 1개
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Motorola Edge (2022) Daughterboard Replacement, Separate the right adhesive: 3 단계, 이미지 3개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Separate the right adhesive: 3 단계, 이미지 3개 중 2개 Motorola Edge (2022) Daughterboard Replacement, Separate the right adhesive: 3 단계, 이미지 3개 중 3개
    • Apply a suction cup to the back of the phone, as close to the middle of the right edge as possible.
    • Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  4. Motorola Edge (2022) Daughterboard Replacement, Slice the right adhesive: 4 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Slice the right adhesive: 4 단계, 이미지 2개 중 2개
    • Slide the pick along the right edge to slice the adhesive.
    • Leave the pick in the bottom right edge to prevent the adhesive from resealing.
  5. Motorola Edge (2022) Daughterboard Replacement, Heat the bottom edge: 5 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the back cover's bottom edge for two minutes.
  6. Motorola Edge (2022) Daughterboard Replacement, Slice the bottom right corner adhesive: 6 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Slice the bottom right corner adhesive: 6 단계, 이미지 2개 중 2개
    • Rotate the pick around the bottom right corner to slice the adhesive.
  7. Motorola Edge (2022) Daughterboard Replacement: 7 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement: 7 단계, 이미지 2개 중 2개
    • Slide the pick along the bottom edge to slice the adhesive.
    • Leave the pick in the bottom left edge to prevent the adhesive from resealing.
  8. Motorola Edge (2022) Daughterboard Replacement: 8 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the back cover's left edge for two minutes.
  9. Motorola Edge (2022) Daughterboard Replacement: 9 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement: 9 단계, 이미지 2개 중 2개
    • Rotate the pick around the bottom left corner to slice the adhesive.
  10. Motorola Edge (2022) Daughterboard Replacement: 10 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement: 10 단계, 이미지 2개 중 2개
    • Slide the pick along the edge to slice the adhesive.
    • Leave the pick in the top left edge to prevent the adhesive from resealing.
  11. Motorola Edge (2022) Daughterboard Replacement: 11 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the back cover's top edge for two minutes.
  12. Motorola Edge (2022) Daughterboard Replacement: 12 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement: 12 단계, 이미지 2개 중 2개
    • Rotate the pick around the top left corner to slice the adhesive.
  13. Motorola Edge (2022) Daughterboard Replacement: 13 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement: 13 단계, 이미지 2개 중 2개
    • Slide the pick along the top edge to slice the adhesive.
  14. Motorola Edge (2022) Daughterboard Replacement, Remove the back cover: 14 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Remove the back cover: 14 단계, 이미지 2개 중 2개
    • Lift the back cover from the phone and remove it.
    • If the back cover is still stuck to the midframe, slide an opening pick around the edges of the phone until the cover separates completely.
  15. Motorola Edge (2022) Daughterboard Replacement, Separate the camera bezel adhesive: 15 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Separate the camera bezel adhesive: 15 단계, 이미지 2개 중 2개
    • Insert an opening pick between the right edge of the camera bezel and the motherboard cover.
    • Slide the pick back and forth along the edge to slice the adhesive.
  16. Motorola Edge (2022) Daughterboard Replacement: 16 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement: 16 단계, 이미지 2개 중 2개
    • Insert an opening pick between the left edge of the camera bezel and the motherboard cover.
  17. Motorola Edge (2022) Daughterboard Replacement, Remove the camera bezel: 17 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Remove the camera bezel: 17 단계, 이미지 2개 중 2개
    • Lift the camera bezel from the phone and remove it.
    • During reassembly:
    • This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
    • If you are replacing the fingerprint sensor or screen assembly, use this guide to calibrate the fingerprint sensor.
    • Follow this guide to replace the back cover and camera bezel adhesive.
  18. Motorola Edge (2022) Daughterboard Replacement, Detach the left wireless charging coil tape: 18 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Detach the left wireless charging coil tape: 18 단계, 이미지 2개 중 2개
    • Insert the pointed end of a spudger underneath the tape that connects the wireless charging coil to the speaker on the bottom left of the phone.
    • Slowly lift the spudger up until the tape detaches from the speaker.
  19. Motorola Edge (2022) Daughterboard Replacement, Detach the right wireless charging coil tape: 19 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Detach the right wireless charging coil tape: 19 단계, 이미지 2개 중 2개
    • Insert a spudger underneath the tape that connects the wireless charging coil to the daughterboard cover on the bottom right of the phone.
    • Slowly lift the spudger up until the tape detaches.
  20. Motorola Edge (2022) Daughterboard Replacement: 20 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement: 20 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the ten 4 mm screws securing the motherboard cover.
  21. Motorola Edge (2022) Daughterboard Replacement: 21 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement: 21 단계, 이미지 2개 중 2개
    • Adhesive secures the motherboard cover to the motherboard itself.
    • Apply a heated iOpener between the bottom edge of the motherboard cover for two minutes.
  22. Motorola Edge (2022) Daughterboard Replacement: 22 단계, 이미지 3개 중 1개 Motorola Edge (2022) Daughterboard Replacement: 22 단계, 이미지 3개 중 2개 Motorola Edge (2022) Daughterboard Replacement: 22 단계, 이미지 3개 중 3개
    • Insert an opening tool between the motherboard cover and the midframe.
    • Pry up with the opening tool until you are able to grab the motherboard cover with your fingers.
    • During reassembly, press down around the perimeter of the motherboard cover to engage the clips.
  23. Motorola Edge (2022) Daughterboard Replacement, Remove the motherboard cover: 23 단계, 이미지 3개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Remove the motherboard cover: 23 단계, 이미지 3개 중 2개 Motorola Edge (2022) Daughterboard Replacement, Remove the motherboard cover: 23 단계, 이미지 3개 중 3개
    • Slowly pull the motherboard cover up and away from the phone and remove it.
  24. Motorola Edge (2022) Daughterboard Replacement, Move the graphite film: 24 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Move the graphite film: 24 단계, 이미지 2개 중 2개
    • Use your fingers to move the graphite film that covers the battery out of the way.
  25. Motorola Edge (2022) Daughterboard Replacement, Disconnect the battery: 25 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Disconnect the battery: 25 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to pry up and disconnect the battery's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  26. Motorola Edge (2022) Daughterboard Replacement, Unfasten the daughterboard cover: 26 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Unfasten the daughterboard cover: 26 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the five screws securing the daughterboard cover:
    • Four 4.1 mm screws
    • One 3 mm screw
  27. Motorola Edge (2022) Daughterboard Replacement, Release the daughterboard cover clips: 27 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Release the daughterboard cover clips: 27 단계, 이미지 2개 중 2개
    • Insert a spudger under the daughterboard cover on the bottom right corner of the phone.
    • Pry up with the spudger to release the clips securing the cover.
  28. Motorola Edge (2022) Daughterboard Replacement, Remove the daughterboard cover: 28 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Remove the daughterboard cover: 28 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use your fingers or tweezers to remove daughterboard cover.
  29. Motorola Edge (2022) Daughterboard Replacement, Disconnect the interconnect cable: 29 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Disconnect the interconnect cable: 29 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to pry up and disconnect the interconnect cable's press connector from the daughterboard.
  30. Motorola Edge (2022) Daughterboard Replacement: 30 단계, 이미지 3개 중 1개 Motorola Edge (2022) Daughterboard Replacement: 30 단계, 이미지 3개 중 2개 Motorola Edge (2022) Daughterboard Replacement: 30 단계, 이미지 3개 중 3개
    • Use your fingers or tweezers to peel back and remove the tape on the fingerprint sensor cover.
    • Set the tape aside for reassembly.
  31. Motorola Edge (2022) Daughterboard Replacement, Unfasten the daughterboard: 31 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Unfasten the daughterboard: 31 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the two 3 mm screws:
    • One screw securing the fingerprint sensor cover.
    • One screw securing the daughterboard.
  32. Motorola Edge (2022) Daughterboard Replacement: 32 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement: 32 단계, 이미지 2개 중 2개
    • Use your fingers or tweezers to remove the fingerprint sensor cover.
  33. Motorola Edge (2022) Daughterboard Replacement: 33 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement: 33 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to pry up and disconnect the fingerprint sensor's press connector.
  34. Motorola Edge (2022) Daughterboard Replacement: 34 단계, 이미지 3개 중 1개 Motorola Edge (2022) Daughterboard Replacement: 34 단계, 이미지 3개 중 2개 Motorola Edge (2022) Daughterboard Replacement: 34 단계, 이미지 3개 중 3개
    • Use the pointed end of a spudger to pry up and disconnect the black antenna's coaxial connector.
    • Pry under the rounded edge of the coaxial connector, not the straight edge. If you pry under the straight edge, you may rip the socket off the daughterboard.
    • Use the spudger to push the antenna up and away from the phone until the cable is freed from the clip securing it to the daughterboard.
    • During reassembly, make sure the cable's metal band connects to the grounding clip in the daughterboard.
    • To re-attach coaxial connectors like this one, hold the connectors in place and gently press them straight down with your finger or the pointed end of a spudger.
  35. Motorola Edge (2022) Daughterboard Replacement: 35 단계, 이미지 3개 중 1개 Motorola Edge (2022) Daughterboard Replacement: 35 단계, 이미지 3개 중 2개 Motorola Edge (2022) Daughterboard Replacement: 35 단계, 이미지 3개 중 3개
    • Repeat the previous step for the white antenna cable.
    • During reassembly, make sure to put the cable back in its clip on the daughterboard.
  36. Motorola Edge (2022) Daughterboard Replacement: 36 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement: 36 단계, 이미지 2개 중 2개
    • Before you perform this step, be sure you’ve ejected the SIM tray.
    • Insert the pointed end of a spudger in the gap between the daughterboard and frame near the right edge of the phone.
    • Gently pry up to release the clips securing the daughterboard.
  37. Motorola Edge (2022) Daughterboard Replacement, Remove the daughterboard: 37 단계, 이미지 2개 중 1개 Motorola Edge (2022) Daughterboard Replacement, Remove the daughterboard: 37 단계, 이미지 2개 중 2개
    • Use your fingers or tweezers to lift the daughterboard out of its recess and remove it.
    • During reassembly, make sure all cables that connect to the daughterboard (interconnect, fingerprint sensor, and antennas) are out of they way so they don't get stuck under the daughterboard when it's reinserted.
결론
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
To reassemble your device, follow the instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
155,120 평판
안내서 1,033개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
1가이드 댓글
Where are you getting this daughter board, I unfortunately cannot seem to find it anywhere.
Andrew Drourr - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 45
전체 시간: 834
