주요 콘텐츠로 건너뛰기
Motorola Edge (2022) Depth Camera Replacement
필요한 것
  1. Motorola Edge (2022) Depth Camera Replacement, Heat the right edge: 1 단계, 이미지 1개 중 1개
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Edge (2022) Depth Camera Replacement, Separate the right adhesive: 2 단계, 이미지 3개 중 1개 Motorola Edge (2022) Depth Camera Replacement, Separate the right adhesive: 2 단계, 이미지 3개 중 2개 Motorola Edge (2022) Depth Camera Replacement, Separate the right adhesive: 2 단계, 이미지 3개 중 3개
    • Apply a suction cup to the back of the phone, as close to the middle of the right edge as possible.
    • Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  3. Motorola Edge (2022) Depth Camera Replacement, Slice the right adhesive: 3 단계, 이미지 2개 중 1개 Motorola Edge (2022) Depth Camera Replacement, Slice the right adhesive: 3 단계, 이미지 2개 중 2개
    • Slide the pick along the right edge to slice the adhesive.
    • Leave the pick in the bottom right edge to prevent the adhesive from resealing.
  4. Motorola Edge (2022) Depth Camera Replacement, Heat the bottom edge: 4 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the back cover's bottom edge for two minutes.
  5. Motorola Edge (2022) Depth Camera Replacement, Slice the bottom right corner adhesive: 5 단계, 이미지 2개 중 1개 Motorola Edge (2022) Depth Camera Replacement, Slice the bottom right corner adhesive: 5 단계, 이미지 2개 중 2개
    • Rotate the pick around the bottom right corner to slice the adhesive.
  6. Motorola Edge (2022) Depth Camera Replacement: 6 단계, 이미지 2개 중 1개 Motorola Edge (2022) Depth Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Slide the pick along the bottom edge to slice the adhesive.
    • Leave the pick in the bottom left edge to prevent the adhesive from resealing.
  7. Motorola Edge (2022) Depth Camera Replacement: 7 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the back cover's left edge for two minutes.
  8. Motorola Edge (2022) Depth Camera Replacement: 8 단계, 이미지 2개 중 1개 Motorola Edge (2022) Depth Camera Replacement: 8 단계, 이미지 2개 중 2개
    • Rotate the pick around the bottom left corner to slice the adhesive.
  9. Motorola Edge (2022) Depth Camera Replacement: 9 단계, 이미지 2개 중 1개 Motorola Edge (2022) Depth Camera Replacement: 9 단계, 이미지 2개 중 2개
    • Slide the pick along the edge to slice the adhesive.
    • Leave the pick in the top left edge to prevent the adhesive from resealing.
  10. Motorola Edge (2022) Depth Camera Replacement: 10 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the back cover's top edge for two minutes.
  11. Motorola Edge (2022) Depth Camera Replacement: 11 단계, 이미지 2개 중 1개 Motorola Edge (2022) Depth Camera Replacement: 11 단계, 이미지 2개 중 2개
    • Rotate the pick around the top left corner to slice the adhesive.
  12. Motorola Edge (2022) Depth Camera Replacement: 12 단계, 이미지 2개 중 1개 Motorola Edge (2022) Depth Camera Replacement: 12 단계, 이미지 2개 중 2개
    • Slide the pick along the top edge to slice the adhesive.
  13. Motorola Edge (2022) Depth Camera Replacement, Remove the back cover: 13 단계, 이미지 2개 중 1개 Motorola Edge (2022) Depth Camera Replacement, Remove the back cover: 13 단계, 이미지 2개 중 2개
    • Lift the back cover from the phone and remove it.
    • If the back cover is still stuck to the midframe, slide an opening pick around the edges of the phone until the cover separates completely.
  14. Motorola Edge (2022) Depth Camera Replacement, Separate the camera bezel adhesive: 14 단계, 이미지 2개 중 1개 Motorola Edge (2022) Depth Camera Replacement, Separate the camera bezel adhesive: 14 단계, 이미지 2개 중 2개
    • Insert an opening pick between the right edge of the camera bezel and the motherboard cover.
    • Slide the pick back and forth along the edge to slice the adhesive.
  15. Motorola Edge (2022) Depth Camera Replacement: 15 단계, 이미지 2개 중 1개 Motorola Edge (2022) Depth Camera Replacement: 15 단계, 이미지 2개 중 2개
    • Insert an opening pick between the left edge of the camera bezel and the motherboard cover.
  16. Motorola Edge (2022) Depth Camera Replacement, Remove the camera bezel: 16 단계, 이미지 2개 중 1개 Motorola Edge (2022) Depth Camera Replacement, Remove the camera bezel: 16 단계, 이미지 2개 중 2개
    • Lift the camera bezel from the phone and remove it.
    • During reassembly:
    • This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
    • If you are replacing the fingerprint sensor or screen assembly, use this guide to calibrate the fingerprint sensor.
    • Follow this guide to replace the back cover and camera bezel adhesive.
  17. Motorola Edge (2022) Depth Camera Replacement, Detach the left wireless charging coil tape: 17 단계, 이미지 2개 중 1개 Motorola Edge (2022) Depth Camera Replacement, Detach the left wireless charging coil tape: 17 단계, 이미지 2개 중 2개
    • Insert the pointed end of a spudger underneath the tape that connects the wireless charging coil to the speaker on the bottom left of the phone.
    • Slowly lift the spudger up until the tape detaches from the speaker.
  18. Motorola Edge (2022) Depth Camera Replacement, Detach the right wireless charging coil tape: 18 단계, 이미지 2개 중 1개 Motorola Edge (2022) Depth Camera Replacement, Detach the right wireless charging coil tape: 18 단계, 이미지 2개 중 2개
    • Insert a spudger underneath the tape that connects the wireless charging coil to the daughterboard cover on the bottom right of the phone.
    • Slowly lift the spudger up until the tape detaches.
  19. Motorola Edge (2022) Depth Camera Replacement: 19 단계, 이미지 2개 중 1개 Motorola Edge (2022) Depth Camera Replacement: 19 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the ten 4 mm screws securing the motherboard cover.
  20. Motorola Edge (2022) Depth Camera Replacement: 20 단계, 이미지 2개 중 1개 Motorola Edge (2022) Depth Camera Replacement: 20 단계, 이미지 2개 중 2개
    • Adhesive secures the motherboard cover to the motherboard itself.
    • Apply a heated iOpener between the bottom edge of the motherboard cover for two minutes.
  21. Motorola Edge (2022) Depth Camera Replacement: 21 단계, 이미지 3개 중 1개 Motorola Edge (2022) Depth Camera Replacement: 21 단계, 이미지 3개 중 2개 Motorola Edge (2022) Depth Camera Replacement: 21 단계, 이미지 3개 중 3개
    • Insert an opening tool between the motherboard cover and the midframe.
    • Pry up with the opening tool until you are able to grab the motherboard cover with your fingers.
    • During reassembly, press down around the perimeter of the motherboard cover to engage the clips.
  22. Motorola Edge (2022) Depth Camera Replacement, Remove the motherboard cover: 22 단계, 이미지 3개 중 1개 Motorola Edge (2022) Depth Camera Replacement, Remove the motherboard cover: 22 단계, 이미지 3개 중 2개 Motorola Edge (2022) Depth Camera Replacement, Remove the motherboard cover: 22 단계, 이미지 3개 중 3개
    • Slowly pull the motherboard cover up and away from the phone and remove it.
  23. Motorola Edge (2022) Depth Camera Replacement, Move the graphite film: 23 단계, 이미지 2개 중 1개 Motorola Edge (2022) Depth Camera Replacement, Move the graphite film: 23 단계, 이미지 2개 중 2개
    • Use your fingers to move the graphite film that covers the battery out of the way.
  24. Motorola Edge (2022) Depth Camera Replacement, Disconnect the battery: 24 단계, 이미지 2개 중 1개 Motorola Edge (2022) Depth Camera Replacement, Disconnect the battery: 24 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to pry up and disconnect the battery's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  25. Motorola Edge (2022) Depth Camera Replacement, Remove the depth camera: 25 단계, 이미지 3개 중 1개 Motorola Edge (2022) Depth Camera Replacement, Remove the depth camera: 25 단계, 이미지 3개 중 2개 Motorola Edge (2022) Depth Camera Replacement, Remove the depth camera: 25 단계, 이미지 3개 중 3개
    • Use the pointed end of a spudger to pry up and disconnect the depth camera's press connector.
    • There's no adhesive securing the depth camera to the motherboard. Be careful disconnecting the press connector, as it may eject the camera.
    • Remove the camera.
결론
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
To reassemble your device, follow the instructions in reverse order.
작성자
3다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
155,120 평판
안내서 1,033개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 17
전체 시간: 264
