주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola MOTO W755 Cell Phone Functional Keypad Replacement
필요한 것
    1. Motorola MOTO W755 Cell Phone Functional Keypad Replacement, Main Logic Board: 1 단계, 이미지 1개 중 1개
      • Using the T5 Torx-screwdriver, remove the four 5.5 mm screws on the back panel.
      댓글 쓰기
    2. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: 2 단계, 이미지 2개 중 1개 Motorola MOTO W755 Cell Phone Functional Keypad Replacement: 2 단계, 이미지 2개 중 2개
      • Using a plastic opening tool, carefully peel back the rubber strip located at the bottom of the keypad
      • Remove the two T5 Torx-screws underneath the rubber strip using the T5 Torx-screwdriver
      댓글 쓰기
    3. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: 3 단계, 이미지 3개 중 1개 Motorola MOTO W755 Cell Phone Functional Keypad Replacement: 3 단계, 이미지 3개 중 2개 Motorola MOTO W755 Cell Phone Functional Keypad Replacement: 3 단계, 이미지 3개 중 3개
      • Using the flat end of the plastic opening tool, insert it in the gap between the charging port and plastic at the bottom left side of the phone.
      • Slide the opening tool around the phone clockwise until you reach the audio port.
      • Twist the opening tool until the plastic pops off from the body of the phone. This make require a small amount of force.
      댓글 쓰기
    4. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the plastic covering completely from the body of the phone.
      댓글 쓰기
    5. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: 5 단계, 이미지 2개 중 1개 Motorola MOTO W755 Cell Phone Functional Keypad Replacement: 5 단계, 이미지 2개 중 2개
      • Using the plastic opening tool, carefully unclip the cable ribbon from the main logic board. Be sure not to tear it because the flex is very fragile.
      • Remove the main logic board.
      댓글 쓰기
    1. Motorola MOTO W755 Cell Phone Functional Keypad Replacement, Functional Keypad: 6 단계, 이미지 1개 중 1개
      • Lift the plastic cover of the keypad from the top of the main logic board and peel it off.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Roberta Glenn
회원 가입일: 07/11/12
43 평판
안내서 4개를 작성함
Cal Poly, Team 1-3, Regan SU 2012 Cal Poly, Team 1-3, Regan SU 2012 회원
CPSU-REGAN-SU12S1G3
2 회원들
안내서 49개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 26
전체 시간: 2,302
