주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Moto 360 Case Locking Fastener Replacement
필요한 것
    1. Motorola Moto 360 Case Locking Fastener Replacement, Wrist Strap: 1 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Locate the spring-loaded pin that attaches the wrist strap to the watch.
      • There is a tiny groove on the end of the pin. This is where you will place the tweezers.
      댓글 쓰기
    2. Motorola Moto 360 Case Locking Fastener Replacement: 2 단계, 이미지 1개 중 1개
      • Take care not to lose the spring-loaded pin when removing the strap.
      • Use the tweezers to compress the spring-loaded pin so the strap can be removed.
      댓글 쓰기
    3. Motorola Moto 360 Case Locking Fastener Replacement: 3 단계, 이미지 2개 중 1개 Motorola Moto 360 Case Locking Fastener Replacement: 3 단계, 이미지 2개 중 2개
      • Pull the wristband away from the watch face.
      댓글 쓰기
    1. Motorola Moto 360 Case Locking Fastener Replacement, Case Locking Fasteners: 4 단계, 이미지 1개 중 1개
      • Locate the rectangular end of the fastener inside the wrist strap mounting pocket.
      댓글 쓰기
    2. Motorola Moto 360 Case Locking Fastener Replacement: 5 단계, 이미지 2개 중 1개 Motorola Moto 360 Case Locking Fastener Replacement: 5 단계, 이미지 2개 중 2개
      • Push the point of the pin in behind the fastener and pry it out. There is a notch near the end of the fastener which will engage the pin. Once the end pops out, the fastener will slide out of the slot easliy. Repeat to remove all four of them.
      • That's it. Now the two halves of the watch can be easily separated by just pulling gently with your fingers.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 18명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Chris K.
회원 가입일: 02/27/17
661 평판
안내서 1개를 작성함
9가이드 댓글
I lost my fasteners... where can I buy more?
thiagopimenta - 답글 공유
One misleading thing about this guide: pictures show the back cover taken off, while in fact you don't need to do this -- just take out the fasteners.
Дмитрий Трубин (Dmitry Trubin) - 답글 공유
Absolutely correct, you don't need to heat or take the back off. I will say though that getting those clips out was damnably fiddly for me.
Ethan Duffy - 답글 공유
ou peut acheter Case Locking Fastener Replacement pour moto360 mon bracelet tien pas
svp chez besoin case locking fastener
abellegarde - 답글 공유
don't remove the back!
follow this video for removing the locking pins.
I did it, so can you!
https://www.youtube.com/watch?v=Jw3n5qbG...
davidlanchart - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 35
전체 시간: 8,454
