소개
The O-Ring is fragile. Take care not to let it break when dealing with it.
필요한 것
Set the watch face down on a flat surface.
Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
Follow the instructions here to remove the back cover without force by using some needles in the right places:
Then continue with step 5. Or don't use needles and just continue with the next steps.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 3개
I broke my o-ring. Any ideas where I could get a raplacement?
Simon Hölz - 답글
i think you should not take the o ring. i was replaceing the battery without take the O ring
