주요 콘텐츠로 건너뛰기
Motorola Moto 360 Rear Cover Replacement
필요한 것
  1. Motorola Moto 360 Rear Cover Replacement, Rear Cover: 1 단계, 이미지 1/1
    • Set the watch face down on a flat surface.
    • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
  2. Motorola Moto 360 Rear Cover Replacement: 3 단계, 이미지 1/2 Motorola Moto 360 Rear Cover Replacement: 3 단계, 이미지 2/2
    • Gently slide the blue opening pick between the rear cover and the metal casing.
    • The rear cover is extremely fragile. Be very delicate when using the opening pick.
    • Work your way entirely around the rear cover.
    • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
  3. Motorola Moto 360 Rear Cover Replacement: 4 단계, 이미지 1/1
    • Once the adhesive has been successfully loosened, gently pull the rear cover off.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Cole Twitchell
회원 가입일: 01/30/15
1,688 평판
안내서 2개 작성하였습니다
Cal Poly, Team 17-32, Amido Winter 2015 Cal Poly, Team 17-32, Amido Winter 2015 회원
CPSU-AMIDO-W15S17G32
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
How does this *rear cover replacement* count as "no parts required"?
Kyle Mitchell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 14
전체 시간: 12,808
