주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Moto E Display Assembly Replacement
필요한 것
  1. Motorola Moto E Display Assembly Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Turn off the device before beginning.
    • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
    • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
    • You should hear a snapping sound at each corner.
    댓글 쓰기
  2. Motorola Moto E Display Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Unscrew the 14 4mm screws using a T4 Torx screwdriver.
    댓글 쓰기
  3. Motorola Moto E Display Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, pry up on the edges of the plastic back cover.
    • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
    댓글 쓰기
  4. Motorola Moto E Display Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
    • Do not touch the connections to the battery in the red square on the picture.
    댓글 쓰기
  5. Motorola Moto E Display Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
    • Move the battery and cover away from the motherboard.
    댓글 쓰기
  6. Motorola Moto E Display Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the three 1 mm screws using a T4 Torx screwdriver.
    댓글 쓰기
  7. Motorola Moto E Display Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Lift up on the white plastic mount.
    • Pull the orange ribbon cable out gently.
    댓글 쓰기
  8. Motorola Moto E Display Assembly Replacement: 8 단계, 이미지 2개 중 1개 Motorola Moto E Display Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Gently pull the black ribbon cable out.
    댓글 쓰기
  9. Motorola Moto E Display Assembly Replacement: 9 단계, 이미지 1개 중 1개
    • Using the metal spudger, pry the motherboard away from the screen assembly.
    댓글 쓰기
  10. Motorola Moto E Display Assembly Replacement, Display Assembly: 10 단계, 이미지 1개 중 1개
    • Use a heat gun or hairdryer to heat up the edges. This will loosen the glue so the screen can be removed.
    • The phone will be extremely hot. Avoid direct contact with metal pieces.
    댓글 쓰기
  11. Motorola Moto E Display Assembly Replacement: 11 단계, 이미지 1개 중 1개
    • Gently slide the metal spudger underneath the screen and pry it away from the backing.
    • Move the metal spudger under the digitizer and along the entire length of the phone to separate the screen from the adhesive.
    • If the screen was broken, glass shards may come off of the screen and puncture skin.
    댓글 쓰기
  12. Motorola Moto E Display Assembly Replacement: 12 단계, 이미지 1개 중 1개
    • Continue to heat and separate until the screen comes completely apart from the rest of the phone.
    댓글 쓰기
  13. Motorola Moto E Display Assembly Replacement: 13 단계, 이미지 1개 중 1개
    • To put the new screen on, press the new screen and digitizer into place, and then reapply heat to adhere the new screen.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 24명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alex Craig
회원 가입일: 03/11/15
2,611 평판
안내서 5개를 작성함
Colorado Springs, Team 5-7, Panko Spring 2015 Colorado Springs, Team 5-7, Panko Spring 2015 회원
UCCS-PANKO-S15S5G7
2 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 67
전체 시간: 32,103
