주요 콘텐츠로 건너뛰기
Motorola Moto E5 Play Battery Replacement
필요한 것
  1. Motorola Moto E5 Play Battery Replacement, Back Cover: 1 단계, 이미지 1/2 Motorola Moto E5 Play Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom right corner of the phone.
    • Pry with your fingernail or twist the spudger to release the back cover's clips from the phone.
  2. Motorola Moto E5 Play Battery Replacement: 2 단계, 이미지 1/2 Motorola Moto E5 Play Battery Replacement: 2 단계, 이미지 2/2
    • Insert your fingernail or the flat end of a spudger into the seam on the bottom of the phone and slide it along the edge to release the clips holding the back cover to the phone.
  3. Motorola Moto E5 Play Battery Replacement: 3 단계, 이미지 1/2 Motorola Moto E5 Play Battery Replacement: 3 단계, 이미지 2/2
    • Continue sliding your fingernail or spudger along the seam around the rest of the phone to release the remaining clips.
  4. Motorola Moto E5 Play Battery Replacement: 4 단계, 이미지 1/2 Motorola Moto E5 Play Battery Replacement: 4 단계, 이미지 2/2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto E5 Play Battery Replacement, Battery: 5 단계, 이미지 1/2 Motorola Moto E5 Play Battery Replacement, Battery: 5 단계, 이미지 2/2
    • Insert your fingernail or the flat end of the spudger into the notch at the bottom of the battery.
    • Pry with your fingernail or spudger to free the battery from its recess.
  6. Motorola Moto E5 Play Battery Replacement: 6 단계, 이미지 1/1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins in the top right of the battery compartment.
결론
Take the time to calibrate your new battery to ensure optimal functionality.
Repair didn’t go as planned? Check out our Motorola Moto E5 Play Answers community for troubleshooting help.
다른 2명이 해당 안내서를 완성하였습니다.
Craig Lloyd
회원 가입일: 02/10/16
35,519 평판
안내서 82개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 104
전체 시간: 6,892
