주요 콘텐츠로 건너뛰기
Motorola Moto G 3rd Generation Battery Replacement
필요한 것
  1. Motorola Moto G 3rd Generation Battery Replacement, Display: 1 단계, 이미지 1/2 Motorola Moto G 3rd Generation Battery Replacement, Display: 1 단계, 이미지 2/2
    • Use your fingernail to pry under the notch on the bottom of the phone and remove the back cover.
    • Make sure to fully power off the phone before you begin disassembly.
  2. Motorola Moto G 3rd Generation Battery Replacement: 2 단계, 이미지 1/2 Motorola Moto G 3rd Generation Battery Replacement: 2 단계, 이미지 2/2
    • Use a heat gun or an iOpener as a heating tool. This guide explains how to use the iOpener.
    • Evenly apply heat to the edges of the touchscreen to loosen the adhesive. Continue to Step 3 once the edge of the screen is warm to the touch.
    • Do not let the iOpener/heat gun remain on one spot for too long. Excess heat can damage the phone.
    • When reassembling the phone, use the iOpener/heat gun to help the adhesive fuse to the new screen. Heat the screen edges, apply pressure to the screen, and hold the screen in place until it is secure.
  3. Motorola Moto G 3rd Generation Battery Replacement: 3 단계, 이미지 1/3 Motorola Moto G 3rd Generation Battery Replacement: 3 단계, 이미지 2/3 Motorola Moto G 3rd Generation Battery Replacement: 3 단계, 이미지 3/3
    • As the adhesive loosens, pry up an edge of the screen with a plastic opening tool or an opening pick. A suction cup may also be useful here.
    • Use an opening pick to hold that edge in place and continue this process around the entire screen, applying more heat as necessary.
    • Avoid damaging the LCD screen connector while prying along the screen edges. It is located on the left edge of the phone, across from the volume controls.
    • During reassembly, new adhesive may need to be applied over the old adhesive to properly secure the screen.
  4. Motorola Moto G 3rd Generation Battery Replacement: 4 단계, 이미지 1/3 Motorola Moto G 3rd Generation Battery Replacement: 4 단계, 이미지 2/3 Motorola Moto G 3rd Generation Battery Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    구매
    • Use a plastic opening tool to flip up the lock on the display cable ZIF connector.
    • Pull the display cable from its socket on the motherboard.
    • When installing a new display, carefully remove all remaining adhesive from the phone, and clean the adhered areas with isopropyl alcohol (90% or greater) and a lint-free cloth. Install the display using pre-cut adhesive or a strong double-sided tape such as Tesa 61395. Turn your phone on and test your repair before sealing the display in place.
  5. Motorola Moto G 3rd Generation Battery Replacement, Motherboard: 5 단계, 이미지 1/1
    • Remove the ten 2.4 mm T4 screws from the sides of the motherboard.
    • Remove the four 4.5 mm T4 screws from the top and bottom of the motherboard.
  6. Motorola Moto G 3rd Generation Battery Replacement: 6 단계, 이미지 1/1
    • If adhesive residue is holding the motherboard in place, use a Jimmy to cut the adhesive between the motherboard and the back of the phone.
    • Carefully lift the right edge of the motherboard from the phone.
    • Avoid pulling on the battery wires, which connect the left underside of the motherboard to the battery.
  7. Motorola Moto G 3rd Generation Battery Replacement: 7 단계, 이미지 1/1
    • Use a plastic opening tool to disconnect the battery wires from the motherboard.
  8. Motorola Moto G 3rd Generation Battery Replacement, Battery: 8 단계, 이미지 1/1
    • Use a spudger to carefully pull the battery wire connector out from under the bridge.
  9. Motorola Moto G 3rd Generation Battery Replacement: 9 단계, 이미지 1/1
    • Pry the battery out of the casing using a spudger.
    • If the battery is hard to pry out, you may need to first apply some heat from the back of the cover using a heat gun or iOpener.
    • When inserting a new battery, new adhesive or tape may be needed to secure it in place.
    • Work carefully. Li-ion batteries can react violently if punctured.
결론
다른 40명이 해당 안내서를 완성하였습니다.
James Copeland
회원 가입일: 02/10/16
4,022 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-3, Nance Spring 2016 USF Tampa, Team 1-3, Nance Spring 2016 회원
USFT-NANCE-S16S1G3
4 회원들
안내서 21개 작성하였습니다
댓글 23개
Thanks a lot, it has been very useful! .. Unfortunately my device is still not working ...
Giovanni Cotella - 답글
No audio sound and ring tone is not working of my Moto G3 set. pl help me what can i do
J. Sarkar
jayanta - 답글
Same here, did you solve it?
Federico Oldani -
Lost all sounds on mine too. But the battery replacement went very smooth.
simivalleydv -
I've extracted the battery and am awaiting a replacement. It holds a charge OK but has bulged to 10mm thick plus some gaseous inflation. This caused the motherboard to bulge in response and popped the screen out of the housing. I suspect that it was, before the "pop" made it obvous, the cause of the failure of the torch/flash. This is because the connection is just by contact pressure between back and motherboard and in the rough centre of the device where the bulge pressure would be most noticeable. So I am hoping for a double cure...
Mike Coon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 29
30일 전: 183
전체 시간: 117,891
