주요 콘텐츠로 건너뛰기
Motorola Moto G Play (2021) Motherboard Cover Replacement
필요한 것
  1. Motorola Moto G Play (2021) Motherboard Cover Replacement, Heat the left edge: 1 단계, 이미지 1/1
    • Discharge your battery to 25% or lower and power off your phone before you begin.
    • Heat an iOpener and apply it to the left edge of the cover for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Moto G Play (2021) Motherboard Cover Replacement, Insert an opening pick: 2 단계, 이미지 1/3 Motorola Moto G Play (2021) Motherboard Cover Replacement, Insert an opening pick: 2 단계, 이미지 2/3 Motorola Moto G Play (2021) Motherboard Cover Replacement, Insert an opening pick: 2 단계, 이미지 3/3
    • Apply a suction cup to the back cover, as close to the center of the left edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the cover and the frame.
    • Insert an opening pick into the gap.
  3. Motorola Moto G Play (2021) Motherboard Cover Replacement, Slice the right adhesive: 3 단계, 이미지 1/3 Motorola Moto G Play (2021) Motherboard Cover Replacement, Slice the right adhesive: 3 단계, 이미지 2/3 Motorola Moto G Play (2021) Motherboard Cover Replacement, Slice the right adhesive: 3 단계, 이미지 3/3
    • Slide your opening pick back and forth along the left edge to slice through the adhesive.
    • Leave the pick in at the bottom left corner to prevent the adhesive from resealing.
  4. Motorola Moto G Play (2021) Motherboard Cover Replacement, Slice the bottom adhesive: 4 단계, 이미지 1/2 Motorola Moto G Play (2021) Motherboard Cover Replacement, Slice the bottom adhesive: 4 단계, 이미지 2/2
    • Insert and slide a second opening pick to the bottom right corner to slice through the adhesive.
    • Leave the pick inserted to prevent the bottom edge from resealing.
    • Repeat this process for the right and top edges of the cover.
  5. Motorola Moto G Play (2021) Motherboard Cover Replacement, Dislodge the fingerprint reader: 5 단계, 이미지 1/3 Motorola Moto G Play (2021) Motherboard Cover Replacement, Dislodge the fingerprint reader: 5 단계, 이미지 2/3 Motorola Moto G Play (2021) Motherboard Cover Replacement, Dislodge the fingerprint reader: 5 단계, 이미지 3/3
    • The fingerprint reader is connected to the motherboard by a fragile cable. You must free it before pulling the cover off.
    • Grab and lift the bottom edge of the cover.
    • As you lift the back cover, press and unstick the fingerprint reader from it.
  6. Motorola Moto G Play (2021) Motherboard Cover Replacement, Remove the back cover: 6 단계, 이미지 1/3 Motorola Moto G Play (2021) Motherboard Cover Replacement, Remove the back cover: 6 단계, 이미지 2/3 Motorola Moto G Play (2021) Motherboard Cover Replacement, Remove the back cover: 6 단계, 이미지 3/3
    • Grab and remove the back cover.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone to slice through any remaining adhesive.
    • Reassembly notes:
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
    • To adhere the back cover with custom-cut adhesives, follow this guide.
    • To adhere the back cover with tape, follow this guide.
  7. Motorola Moto G Play (2021) Motherboard Cover Replacement, Reposition the fingerprint reader: 7 단계, 이미지 1/2 Motorola Moto G Play (2021) Motherboard Cover Replacement, Reposition the fingerprint reader: 7 단계, 이미지 2/2
    • Flip the fingerprint reader to the left, away from the phone.
    • Don't fold or sharply bend the ribbon cable.
  8. Motorola Moto G Play (2021) Motherboard Cover Replacement, Unfasten the motherboard cover: 8 단계, 이미지 1/2 Motorola Moto G Play (2021) Motherboard Cover Replacement, Unfasten the motherboard cover: 8 단계, 이미지 2/2
    • Use your Phillips screwdriver to remove the twelve 3.9 mm-long screws securing the motherboard cover.
  9. Motorola Moto G Play (2021) Motherboard Cover Replacement, Pry the motherboard cover: 9 단계, 이미지 1/2 Motorola Moto G Play (2021) Motherboard Cover Replacement, Pry the motherboard cover: 9 단계, 이미지 2/2
    • Insert the pointed end of a spudger between the bottom right corner of the motherboard cover and the frame.
    • Pry the cover upward until you can grab it with your fingers.
  10. Motorola Moto G Play (2021) Motherboard Cover Replacement, Remove the motherboard cover: 10 단계, 이미지 1/2 Motorola Moto G Play (2021) Motherboard Cover Replacement, Remove the motherboard cover: 10 단계, 이미지 2/2
    • Grab the bottom edge of the motherboard cover and remove it from the frame.
결론
Clay Eickemeyer
회원 가입일: 09/19/22
66,907 평판
안내서 453개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,199개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 121
