소개
This guide will walk you through the process of replacing the motherboard in a Motorola Moto G4 Plus phone.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
필요한 것
Insert a fingernail or a spudger into the notch on bottom edge of the phone near the charging port.
Pry the back cover away from the body of the phone.
Slide out and remove the SIM card.
Tenho un Motorola g4 plus 64 G
El celular se volvía loco abriendo y cerrando aplicaciones
Ahora no reconoce la tarjeta SIM
Internet y Wasapp funciona
Alguien sabe donde lo reparan soy de Argentina Buenos Aires CABA
Remove the nineteen 3.1 mm T3 screws securing the midframe.
A pair of binocular magnifiers is helpful here. Also, a magnetic pickup will help pull the tiny screws out of their counterbores.
Well I'm stuck. 3 screw heads are stripped on mine, not lucky as they are two on USB port end and screw in-between two SIM slots. Phone bought new and this is 1st time screws have been touched, could see they were already stripped before getting screwdriver near them. Any tips on removing stripped screws?
Hi Mark,
I’m sorry to hear that! You can try some techniques from the stripped screw guide.
I found that a T4 driver was the correct size for the screws.
Peel the black pull tab from battery and pull slowly but firmly to separate the battery from the frame.
Does anybody know, what the black tape covering the metal cans an the battey is made of? It seems to have a heat insulating effect.
No, but the tape completely separated from itself when I removed it. Glue separated from the backing. I figure the glue in the frame is holding it well enough.
I found prying the battery out was the trickiest part of this job. Take your time and pry with the plastic tool, working from the end away from the wires, but try not to deform the battery in the process. It does finally come out.
Hi, I cannot remove the Battery, it has too strong glue. Any Ideas?
Regards
You can try to drip some high concentration isopropyl alcohol along the battery edge to help loosen the adhesive.
Using tweezers, lift up the black silicon piece connecting the motherboard to the front casing.
Using tweezers, remove the red and black cable connecting the motherboard to the front casing.
Using a spudger, remove the two metal pieces connecting the motherboard to the front casing.
What is the purpose of that metal piece that is connected to the motherboard on the bottom left-hand side.
Its for the fingerprint scanner (only on the G4 Plus)
다른 33명이 해당 안내서를 완성하였습니다.
댓글 14개
sir, my motorola g4-plus suddenly it off . i am not analyzed that problem, please help me
Hi,
My Moto G4 Plus has suddenly Dead. neither it is getting charged nor showing any response.
Please Help me. Its just 13 Months have been passed buying me this.
Sir i have a moto g4 plus handset sir when i press power button the device gets locked and when i press power button to open the phone the phone does not open and i have to restart the phone to unlock it and when i unlock it the phones works properly what could be the problem help me
please help me with the motherboard i wana buy motherboard for moto g4plus . phn got dead no power nothing is cuming even not service centre is ready to repair
i have moto e4 plus handset handset was locked and technician says that mother board proble wthat is the price of mother board
Moto g4 plus mother board cast
Don't buy this Motorola/lenova poor product mobile..i also loss 15k in just 21 months.
What is the motherboard price Moto G 4 plus
Please me you sir
Hi Mera moto g4 plus mobile pani me gir Gaya sarvice senter par dikaya to motherboard karab h muje thik karna kya new motherboard mil jaye game kya sarvice senter pe menga h
Motherboard s ki kya cost h
Sorry, we currently do not sell this part.
kshama karen ham vartamaan mein is bhaag ko nahin bechate hain.
How to buy motherboard
My moto g4 plus motherboard problems new motherboard price
My friend’s Moto G4 Plus seems to have a dead microphone. When she calls me, I can’t hear her, but she can hear me. She tried rebooting, but it did not help. She has had intermittent microphone problems with other calls, where they could hear her, but sound cut in and out.
I’m not seeing anything about microphone replacement. Is it on the motherboard, or maybe it’s part of the camera? Is there a fix for the microphone?
