주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola RAZR Maxx HD Battery Replacement
필요한 것
  1. Motorola RAZR Maxx HD Battery Replacement, Screen Removal: 1 단계, 이미지 2개 중 1개 Motorola RAZR Maxx HD Battery Replacement, Screen Removal: 1 단계, 이미지 2개 중 2개
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
    댓글 쓰기
  2. Motorola RAZR Maxx HD Battery Replacement: 2 단계, 이미지 2개 중 1개 Motorola RAZR Maxx HD Battery Replacement: 2 단계, 이미지 2개 중 2개
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
    댓글 쓰기
  3. Motorola RAZR Maxx HD Battery Replacement: 3 단계, 이미지 2개 중 1개 Motorola RAZR Maxx HD Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
    댓글 쓰기
  4. Motorola RAZR Maxx HD Battery Replacement: 4 단계, 이미지 2개 중 1개 Motorola RAZR Maxx HD Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
    댓글 쓰기
  5. Motorola RAZR Maxx HD Battery Replacement, Circuit Board: 5 단계, 이미지 3개 중 1개 Motorola RAZR Maxx HD Battery Replacement, Circuit Board: 5 단계, 이미지 3개 중 2개 Motorola RAZR Maxx HD Battery Replacement, Circuit Board: 5 단계, 이미지 3개 중 3개
    • Remove the plastic yellow tape on the battery connector using the spudger.
    • Pry up on the orange connection to release it from the motherboard.
    댓글 쓰기
  6. Motorola RAZR Maxx HD Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Unscrew all ten 4.0 mm screws on the motherboard using a T5 Torx screwdriver.
    댓글 쓰기
  7. Motorola RAZR Maxx HD Battery Replacement: 7 단계, 이미지 2개 중 1개 Motorola RAZR Maxx HD Battery Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers, remove the clear plastic covering on the speaker.
    • Pry open the connection by lifting up on the speaker wire connector.
    댓글 쓰기
  8. Motorola RAZR Maxx HD Battery Replacement: 8 단계, 이미지 2개 중 1개 Motorola RAZR Maxx HD Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Using tweezers, remove the back facing camera cover.
    댓글 쓰기
  9. Motorola RAZR Maxx HD Battery Replacement: 9 단계, 이미지 2개 중 1개 Motorola RAZR Maxx HD Battery Replacement: 9 단계, 이미지 2개 중 2개
    • Using the spudger tool, release the yellow ribbon cable on the headphone jack cover by pushing up on the connection.
    • Remove the cover from the motherboard.
    댓글 쓰기
  10. Motorola RAZR Maxx HD Battery Replacement: 10 단계, 이미지 1개 중 1개
    • Release the yellow flex cable on the right side of the phone using the spudger by lifting up on the retaining clip.
    댓글 쓰기
  11. Motorola RAZR Maxx HD Battery Replacement: 11 단계, 이미지 3개 중 1개 Motorola RAZR Maxx HD Battery Replacement: 11 단계, 이미지 3개 중 2개 Motorola RAZR Maxx HD Battery Replacement: 11 단계, 이미지 3개 중 3개
    • Wedge the spudger between the motherboard and the back case.
    • Work your way around the entire edge of the motherboard to release it and remove it from the back of the phone.
    댓글 쓰기
  12. Motorola RAZR Maxx HD Battery Replacement, Battery: 12 단계, 이미지 2개 중 1개 Motorola RAZR Maxx HD Battery Replacement, Battery: 12 단계, 이미지 2개 중 2개
    • Wedge the spudger tool under the battery to remove it from the back case.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 12명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Anna Sullivan
회원 가입일: 02/01/15
880 평판
안내서 3개를 작성함
Cal Poly, Team 8-40, Amido Winter 2015 Cal Poly, Team 8-40, Amido Winter 2015 회원
CPSU-AMIDO-W15S8G40
5 회원들
안내서 27개를 작성함
1가이드 댓글
When putting it all back together, is it recommended to replace the pieces of tape to protect/insulate the connectors, or is that not necessary?
FreeMan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 32
전체 시간: 5,942
