주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola RAZR Maxx HD Screen Replacement
필요한 것
  1. Motorola RAZR Maxx HD Screen Replacement, Screen Removal: 1 단계, 이미지 2개 중 1개 Motorola RAZR Maxx HD Screen Replacement, Screen Removal: 1 단계, 이미지 2개 중 2개
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
    댓글 쓰기
  2. Motorola RAZR Maxx HD Screen Replacement: 2 단계, 이미지 2개 중 1개 Motorola RAZR Maxx HD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
    댓글 쓰기
  3. Motorola RAZR Maxx HD Screen Replacement: 3 단계, 이미지 2개 중 1개 Motorola RAZR Maxx HD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
    댓글 쓰기
  4. Motorola RAZR Maxx HD Screen Replacement: 4 단계, 이미지 2개 중 1개 Motorola RAZR Maxx HD Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
    댓글 쓰기
  5. Motorola RAZR Maxx HD Screen Replacement, Front-Facing Camera: 5 단계, 이미지 1개 중 1개
    • On the back of the LCD display, release the yellow front-facing camera ribbon cable by gently lifting upward on the black retaining clip with the spudger.
    댓글 쓰기
  6. Motorola RAZR Maxx HD Screen Replacement: 6 단계, 이미지 3개 중 1개 Motorola RAZR Maxx HD Screen Replacement: 6 단계, 이미지 3개 중 2개 Motorola RAZR Maxx HD Screen Replacement: 6 단계, 이미지 3개 중 3개
    • With a Torx T3 screwdriver, unscrew the two 2.0 mm screws on front-facing camera mounting bracket. Then lift to remove it.
    댓글 쓰기
  7. Motorola RAZR Maxx HD Screen Replacement: 7 단계, 이미지 2개 중 1개 Motorola RAZR Maxx HD Screen Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to remove the front-facing camera by lifting it from the LCD display frame.
    댓글 쓰기
  8. Motorola RAZR Maxx HD Screen Replacement, Earpiece Speaker: 8 단계, 이미지 1개 중 1개
    • Insert the spudger between the speaker and retaining clip and gently pry upward to release the earpiece speaker.
    댓글 쓰기
  9. Motorola RAZR Maxx HD Screen Replacement: 9 단계, 이미지 2개 중 1개 Motorola RAZR Maxx HD Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Using a spudger, gently pry up on the lower right edge of the black earpiece speaker ribbon cable, attached to the screen, to release it from the LCD display.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Enrique
회원 가입일: 02/01/15
371 평판
안내서 2개를 작성함
Cal Poly, Team 8-40, Amido Winter 2015 Cal Poly, Team 8-40, Amido Winter 2015 회원
CPSU-AMIDO-W15S8G40
5 회원들
안내서 27개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 25
전체 시간: 3,174
