주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola RAZR2 v9m Keypad Replacement
필요한 것
  1. Motorola RAZR2 v9m Keypad Replacement, Battery: 1 단계, 이미지 2개 중 1개 Motorola RAZR2 v9m Keypad Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Push the rear cover toward the hinge of the RAZR2. The panel will slide about 3 mm.
    댓글 쓰기
  2. Motorola RAZR2 v9m Keypad Replacement: 2 단계, 이미지 3개 중 1개 Motorola RAZR2 v9m Keypad Replacement: 2 단계, 이미지 3개 중 2개 Motorola RAZR2 v9m Keypad Replacement: 2 단계, 이미지 3개 중 3개
    • Pinch the top and bottom edges of the panel and pull it away from the RAZR2.
    • The rear panel uses four small hooks to hold it in place. If the panel will not easily pull away, slide the panel more toward the hinge.
    댓글 쓰기
  3. Motorola RAZR2 v9m Keypad Replacement: 3 단계, 이미지 2개 중 1개 Motorola RAZR2 v9m Keypad Replacement: 3 단계, 이미지 2개 중 2개
    • Gently pull the white plastic tab to lift the battery away from the RAZR2.
    • The white plastic tab is attached to the phone. Only pull it enough to expose the edges of the battery.
    댓글 쓰기
  4. Motorola RAZR2 v9m Keypad Replacement: 4 단계, 이미지 2개 중 1개 Motorola RAZR2 v9m Keypad Replacement: 4 단계, 이미지 2개 중 2개
    • To remove the battery, grasp its edges pull away from the phone.
    • When installing a new battery, be sure the metal contacts on the phone line up with the ones on the battery.
    댓글 쓰기
  5. Motorola RAZR2 v9m Keypad Replacement, Keypad: 5 단계, 이미지 3개 중 1개 Motorola RAZR2 v9m Keypad Replacement, Keypad: 5 단계, 이미지 3개 중 2개 Motorola RAZR2 v9m Keypad Replacement, Keypad: 5 단계, 이미지 3개 중 3개
    • Flip the RAZR2 open with the battery compartment facing you.
    • Pull the white battery tab away from the phone to reveal a small black gap in the battery compartment.
    • Place the spudger into this gap. Rest the spudger against the black plastic inside of the gap.
    댓글 쓰기
  6. Motorola RAZR2 v9m Keypad Replacement: 6 단계, 이미지 3개 중 1개 Motorola RAZR2 v9m Keypad Replacement: 6 단계, 이미지 3개 중 2개 Motorola RAZR2 v9m Keypad Replacement: 6 단계, 이미지 3개 중 3개
    • Rest the spudger/scewdriver between the top of the black plastic and the metal body of the phone and leaver the two apart to release the top clip on the keyboard.and the top of the keypad pops out from the RAZR2.
    댓글 쓰기
  7. Motorola RAZR2 v9m Keypad Replacement: 7 단계, 이미지 3개 중 1개 Motorola RAZR2 v9m Keypad Replacement: 7 단계, 이미지 3개 중 2개 Motorola RAZR2 v9m Keypad Replacement: 7 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to gently pry one side of the keypad away from the RAZR2.
    • There are 2 clips on the side of the keypad. In total, there are 8 clips holding the keypad to the phone.
    댓글 쓰기
  8. Motorola RAZR2 v9m Keypad Replacement: 8 단계, 이미지 3개 중 1개 Motorola RAZR2 v9m Keypad Replacement: 8 단계, 이미지 3개 중 2개 Motorola RAZR2 v9m Keypad Replacement: 8 단계, 이미지 3개 중 3개
    • Lift the keypad away from the phone.
    • When reassembling, gently squeeze the sides of the keypad until the keypad has a slight bow running down the middle from top to bottom, like a playing card. This will ensure that it slides easily into place. Take care not to damage any of the 8 clips.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Sam Roach
회원 가입일: 06/04/13
152 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 38
전체 시간: 1,707
