주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola RIZR Z3 LCD Replacement
필요한 것
  1. Motorola RIZR Z3 LCD Replacement, Battery: 1 단계, 이미지 2개 중 1개 Motorola RIZR Z3 LCD Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
    댓글 쓰기
  2. Motorola RIZR Z3 LCD Replacement: 2 단계, 이미지 2개 중 1개 Motorola RIZR Z3 LCD Replacement: 2 단계, 이미지 2개 중 2개
    • Tilt the battery by lifting at the exposed notch.
    • Slide the battery out of its casing.
    댓글 쓰기
  3. Motorola RIZR Z3 LCD Replacement, Motherboard: 3 단계, 이미지 1개 중 1개
    • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
    댓글 쓰기
  4. Motorola RIZR Z3 LCD Replacement: 4 단계, 이미지 2개 중 1개 Motorola RIZR Z3 LCD Replacement: 4 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to lift the plastic casing.
    • Pull the plastic casing directly away from the phone.
    댓글 쓰기
  5. Motorola RIZR Z3 LCD Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the black rubber loudspeaker housing up and out of the plastic casing.
    댓글 쓰기
  6. Motorola RIZR Z3 LCD Replacement: 6 단계, 이미지 2개 중 1개 Motorola RIZR Z3 LCD Replacement: 6 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
    • Caution: Remove carefully, if broken, the phone will not be able to make calls.
    댓글 쓰기
  7. Motorola RIZR Z3 LCD Replacement: 7 단계, 이미지 2개 중 1개 Motorola RIZR Z3 LCD Replacement: 7 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
    • Caution: Remove carefully, if broken, the phone will not function properly.
    댓글 쓰기
  8. Motorola RIZR Z3 LCD Replacement: 8 단계, 이미지 2개 중 1개 Motorola RIZR Z3 LCD Replacement: 8 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
    • Caution: Do this gently Unclipping too fast may cause damage to your phone.
    댓글 쓰기
  9. Motorola RIZR Z3 LCD Replacement, LCD: 9 단계, 이미지 1개 중 1개
    • Turn the phone to the front.
    • Push the keypad out through the plastic casing.
    댓글 쓰기
  10. Motorola RIZR Z3 LCD Replacement: 10 단계, 이미지 1개 중 1개
    • Turn the phone to the side.
    • Thread the hinges of the slider through their holes in the casing and pull the slider down and away from the casing.
    댓글 쓰기
  11. Motorola RIZR Z3 LCD Replacement: 11 단계, 이미지 1개 중 1개
    • Use a T4 screwdriver to unscrew the two .15 inch screws holding the LCD to the faceplate.
    댓글 쓰기
  12. Motorola RIZR Z3 LCD Replacement: 12 단계, 이미지 3개 중 1개 Motorola RIZR Z3 LCD Replacement: 12 단계, 이미지 3개 중 2개 Motorola RIZR Z3 LCD Replacement: 12 단계, 이미지 3개 중 3개
    • Use a spudger to pry the plastic screen casing partially up from the LCD unit.
    • Use the spudger to pry the ribbon cable away from its clip on the LCD unit.
    • Caution: Do this carefully, damage to this ribbon cable will cause a blank screen.
    • Pull the plastic screen casing directly away from the LCD unit.
    댓글 쓰기
  13. Motorola RIZR Z3 LCD Replacement: 13 단계, 이미지 2개 중 1개 Motorola RIZR Z3 LCD Replacement: 13 단계, 이미지 2개 중 2개
    • Use a spudger to lift the LCD partially away from the metal casing.
    • Use the spudger to pry the ribbon cable directly up from its clip on the metal casing.
    • Caution: Damage to the ribbon cable here will cause screen damage.
    • Pull the LCD completely away from the metal casing.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Brooke Shuford
회원 가입일: 10/10/11
65 평판
안내서 3개를 작성함
Cal Poly, Team 5-34, Amido Fall 2011 Cal Poly, Team 5-34, Amido Fall 2011 회원
CPSU-AMIDO-F11S5G34
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 30
전체 시간: 1,312
